Gtechniq exo v3
Gregj7105
So i buffed the whole car and it looked amazing. Then i wiped it down with Gtechniq wipe, then applied 2 coats of exo v3, and everything looked great. It sat in the garage for over 12 hours. Left it outside because im working on another project that wants the exo v3. The problem is i tried to wipe off the dirt with detail spray. The dirt and water marks that were on the car are not coming off the car. Almost like its in the coating or on the clear itself. Like everything burned itself onto the car. i took a picture but for some reason i cant up load it here. what went wrong? how do i fix it or make sure it doesnt happen again?
Likely that the coating wasn't fully cured when you took it outside, then dirt got on the coating and embedded itself, then coating cured enough to harden up. You can try claying to remove the embedded dirt and cross your fingers it doesn't compromise the coating. Else, it's polish and reapply
