Guide to Leather Care?
willowcat11
Member
I just received an email from AG showing a guide to Leather care using Pinnacle Black Products. I was surprised to see that they used a Leather Conditioner first, and then used a Coating over it.
Now this may ONLY be with using the Pinnacle Black Products. I have been using Wolfgang products over the past couple months, and when I began cleaning and caring for my leather, I was of the assumption that using a Leather Conditioner or a Sealant was an either/or ordeal. Mainly because the conditioner might cause problems with the sealant getting absorbed in also.
So in my case, I just have been using WG Cockpit Trim Sealant. Now seeing this Black Label Leather Article, can I condition my leather with the WG Leather Conditioner, then top it with the WG Cockpit Trim Sealant?
Thank you!
Ray
I'm always curious about this as well. Everyone seems to have a different opinion. The few "leather" pieces I have in my truck get cleaned, conditioned, and sealed. I try not to overthink as I drive myself nuts.
I've been really wanting to try this stuff out, but I still have Wolfgang Interior Sealant. Do you use this on everything including vinyl and plastics? How's the durability?
I try not to overthink...
•Being that also try to not overthink
automotive leather-care...
-I use leather-care products that follow
the premise of: "Clean and Protect"
Conversely:
•Automotive leather-care products that contain
conditioners/conditioning oils, such as: collagen,
neatsfoot oil, lanolin, liquified pig fat ("mink oil"),
aloe, synthetic Sperm Whale oil, "banana oil", etc.
-Not so much!
11Silverado,
I use it on everything in my Interior. There is A LOT of Vinyl Trim in my interior, and then also all of my leather. Everything is the same exact color, so everything looks very uniform, especially when WG Cockpit Trim Sealant evens out everything very nicely.
The durablity has been Excellent(a couple months now, and still looks like the day I applied it)! Because my interior was very neglected from the previous owner, I ended up putting on 3 applications, and buffing off any leftover product. And then this accomplished the look and feel I was really after. I'm figuring most "taken care of" cars will not need that many apps.
My maintenance on the interior surfaces is only using a damp Microfiber cloth to wipe everything down with. I haven't had the need to use a cleaner or detailer on anything yet.
"•Being that also try to not overthink
automotive leather-care..."
I am "Really" bad at overthinking this stuff. Thank you guys for reminding me that I am not alone in that struggle with this stuff, and that I don't need to get to carried away with these things.
Ray
The three most common types of automotive leather are:
Aniline: Leather that has been dyed and coated with a pigment (colored urethane paint) to yield uniform color and then clear coated. This type of leather does not reveal scars, pores and blemishes and has an artificial uniform grain pattern embossed. It is typically the only real leather in the seat and located only in the center inserts of the seat. The sides, bolsters, etc., are vinyl painted with the same colored urethane paint so it matches the leather inserts perfectly giving the entire seat a "leather" look. This is what 99% of cars have including Corvette, Escalade, newer Ferrari and Lamborghini. To demonstrate this just put a drop of water on your seat and see if it soaks in. It will not soak in as the leather has a painted on urethane coating on it. If water can't penetrate the coating how can "conditioners" and "protectants?" Read on.....
Semi-Aniline: Leather that has been dyed and coated with a semi-transparent pigment then clear coated This type of leather may reveal some of the underlying scars and blemishes of the hide as well as some color and grain changes. Almost never seen in the past twenty years.
Synthetic: Much of the leather, and in some, all of the leather in many of today's vehicles is entirely synthetic or engineered leather. It looks like real leather but is really entirely synthetic. This is in use in some high ticket brands like Lexus, MB and Infinity for example. It is often difficult to tell what is real leather and what is engineered leather.
The bottom line is 99.9% of cars sold today have leather only on the middle insert of the seat bottom and back. The sides are completely 100% vinyl. The color and texture of the vinyl matches the leather inserts perfectly as they are all sprayed with a colored urethane coating. A perfect way to demonstrate they are vinyl is the water drop test outlined above. Another way is pull some of the seat siding out from underneath the seat. Notice there is a foam backing? Real leather (from real cows) doesn't have foam backing on it.
Have you noticed the change in new car window stickers when referring to the seats? They now call the interior "leather lined," or "leather trim." Just take a look at a new C7 Corvette window sticker. They don't say "leather seats" like they used to. Now the C7 window sticker says, "Trim, Leather." This is because only the center inserts are actually leather! The remainder of the seat is vinyl. Remember, vinyl has a foam backing on it.
Everyone seems to like the term "conditioner," but just what is conditioning? When leather professionals speak of “conditioning leather” they are usually speaking about leather hydration. Properly hydrated leather will be soft, plump and flexible making it resistant to creasing and cracking. Most traditional conditioners are typically oily or contain silicone, wax or things like Aloe or Neat's-foot or Mink oil. No protected, urethane coated, leather needs or benefits from these things. Conditioning products were initially designed for a much different type of leather like car seat who were 100% uncoated leather back in the 60's and 70's. Remember, none of these conditioners can absorb through the urethane coating making them useless.
Most oily conditioners leave a film on protected leather that can hasten the accumulation of soil. Dirt is attracted to the oil as it sits on top of the urethane coating. Your butt rubbing back and forth across this dirt acts like sandpaper and actually buffs the colored urethane coating off.
Conditioners do not penetrate the urethane painted top coat to condition the leather. True, some of the H2o in these conditioners evaporates and raises the relative humidity surrounding the leather which is beneficial as the leather will pick up the H2o through the process of transpiration, but a damp wipe down with a towel will do this as well and not leave that soil grabbing film.
Keep in mind that the colored urethane topcoat was added to the leather for the purpose of preventing spills and liquids from getting to the leather, as well as hiding the leather’s underlying scars, and blemishes, while making the leather more abrasion resistant. The urethane topcoat is colored so all of the surfaces of the seat match the door panels, dashboard, etc. If they did not contain coloring, every single piece of "leather" in your car would not match.
Leather conditioners do nothing to prevent stains or dye transfer. If your leather has developed cracks, using an oily conditioner may further degrade the adhesion of the painted topcoat around the crack and make the damage worse. Doesn't wet paper tear much easier than dry paper?
So how does this painted on protective urethane coating work and still allow the leather to stay hydrated? Much the same way as a rain coat would protect you from a driving rain. At the same time the rain is being repelled, you will begin to notice that your clothing is becoming damp due to the 100% humidity level. That's basically how your leather stays hydrated, at the molecular level. If you want to test this put a drop of water on your protected leather in an inconspicuous place and leave for 15-20 minutes and you will see that it does not soak in. That is the urethane top coat preventing the absorption of the liquid as it was designed to do. H2o is a small molecule when compared to an oily conditioner so if water is not being absorbed by the leather, the larger molecules of a conditioner certainly are not.
Ok, so for those who insist that their leather feels softer after using a conditioner I can suggest three reasons for this. The first is that the conditioner has left an oily film on the leather and it altered the "hand" or feel of the leather. It has not really done anything to the leather, as it can't get to the leather, but it makes the hand feel nice for a short time until it is rubbed off or evaporates.
The other reason is that the conditioner likely contains a good deal of water and that it is raising the humidity level in the proximity of the leather. If this happens, the leather may absorb the water molecules and plump up and feel softer. The thing about this is that a wipe down with a wrung out watered cotton towel would accomplish the exact same thing.
The third reason is that the term conditioner has no defined meaning. Who knows what is in the bottle labeled Leather Conditioner? What one company calls a conditioner another might call a protectant. Whatever your "conditioner" is will just give you the impression the leather is softer when you touch it since it is slick. It is certainly not "conditioned" since it cannot absorb into the leather or vinyl portion of your seats. Bottom line is the industry has too many vague definitions as to exactly what "conditioning" is.
Leather is made soft in the tanning process and then sealed. You cannot add oils back through the urethane topcoat of protected leather. Leather becomes hard if it loses its needed hydration. Dry leather shrinks and feels hard. Much the same way a chamois gets hard when it is dry. Rehydrate the chamois and it becomes soft again. Rehydrate unprotected leather seats and they should soften to the degree designed in the original tanning process. Think about it.
I never use products that contain neat's-foot, mink, or other oils, silicone, aloe, or any other odd, useless item, but often the labels doesn't tell you what is in the bottle. This includes Leatherique, Lexol, 303 Protectant, Armor All, Zaino, etc., etc. In my experience, these products do nothing but sit on top of the urethane top coating until your clothing wipes them off. In the meantime, they collect dust and dirt which is then ground into your seats and stitching as you slide across the seat getting in and out much like sandpaper. 90% of your seat damage comes from this!
I vacuum the leather in my C6, Ferrari 360 and Lambo Gallardo and wipe it down with a wrung out watered towel weekly. That is it! Your leather will look like brand new for many years to come! My C6 is ten years old and the seats still look like brand new!
You are going to read a lot of people who make comments disagreeing with me. Just conduct the two above tests and make your own decisions. Does a drop of water soak into the seat or just sit on top until it evaporates? Does the backing of your seat material on the side pieces (bolster) have foam on the back? Remember, your seats may feel softer after applying a "conditioner," but go back in a day or two and see if they still feel that way. Once the conditioner dries on the seats and on your hands, this softness is gone! Lastly, if Corvette seats are 100% leather, why has GM changed their description on Window Stickers as "Trim, Leather?" Enuf said!
@Rob4092xx. Yea yea.. People like myself use leather conditioner because it slightly darkens the surface and adds a nice subtle sheen, plus it smells Great!
The leather conditioner I use doesn't rub off on anyones clothes, nor does it attract dirt. How do I know this? Because I can wipe the whole interior down with Megs D181 Leather Cleaner 7 days later and there's almost no dirt visible on the white terry towel.
People always talk about how leather conditioner supposedly attracts dirt that will lead to it abrading against the seats.. I think that's way overblown. How much dirt can someone possibly allow into their vehicle in order for that to actually happen? It's outrageous.
@Rob4092xx:
•With what type/(types?) of leather,
if any, is this C7's seats appointed?
•Where's the vinyl, if any, located?
TIA.
watermark.php
watermark.php
Pulled this from Autopia
Top leather cleaner/conditioner picks for leather steering wheel in 2015 VW Golf. - Page 2
Doesn't matter what type, if it is coated, you are just cleaning the coating not the actual material underneathe.
To a degree....coated leather doesn't mean impenetrable or in this case impermeable.
Click here to view the original image of 800x515px.
Care
Caring for pigmented leather is truly about keeping the leather clean. Dirt and particulate will scratch and wear the leather leading to shiny appearance and exposure of the leather hide underneath. Acidic body oils can wear or stain the vacuum frequently and use a gentle, water based cleaner to remove embedded dirt and oil. Use a protectant or conditioner that features protectants (to reduce abrasion and increase sun fade resistance). Over time the leather coating will crack microscopically or stretch in the seams and folds. Conditioners can penetrate the coating through these cracks and openings, keeping the leather underneath soft and supple.
Wow. This is exactly what I was looking for. The people who made my seat covers said the same thing. Water on damp cloth and do it often. I am 3 years in and other than increased cracks (which I think are normal) good to go. The driver seat is the only one used, the rest look brand new.
The only leather on a C7, in fact all Chevrolet's, is the center piece on the seat and the upright seat where your back meets the seat. If you don't believe me look at the backside of any piece of the seat except the center pieces and you will see a white cloth/thin foam backing. Cows don't have this on their hides so it is safe to assume it is not leather.
So if I have aniline leather and vinyl comprising my seats and I clean them with a damp cloth, is there a recommended product I can use every 3-6 months to maintain that urethane coating? I have an older vehicle where the driver's side bolster has cracked and torn (vinyl) and I would like to avoid that with proper maintenance if possible on a newer car. To keep things simple I was thinking: Optimum Protectant Plus offers complete protection for interior leather, vinyl, plastic & rubber dressing. vinyl and rubber dressing, vinyl
If you don't believe me look.
I've looked at my C7's seating appointments
on many occasions; and, as such: I find your
above statement to not be factual.
I'm not sure if anyone else has tried this but I used diluted CarPro P.E.R.L. on Chrysler 300 leather. I'm fairly certain that this is coated leather. The results were pretty great. It wasn't greasy at all and seemed to clean the leather at the same time. It gave the black leather a very slight shine which looked pretty good to me.
Bob, I don't know if your Leather is the Color that is shown in the photo you showed, but if so, that is a Beautiful color man!
Sorry but this comment is sort of meaningless without pictures... Smh.
color man!
Yes it is...Thank you! :xyxthumbs:
Ever hear that saying:
"Better look before you leap"!?!?
While you were "shaking"...
You must have (in)advertantly overlooked
Post#10 in this thread.
:laughing:
