Ice helps as it turns hard the gum, then you can peel it off.customer called wants the inside of his van cleaned, vac,one seat has gum on it. What can i use to remove it from leather seats, was told ice is that true? Need suggestions. Thanks:righton:
I have never tried it, but I have heard the same. Good luck!Ice helps as it turns hard the gum, then you can peel it off.
2 ways to get gum off..one is ice and freeze it and get most off and then use a conditioner to get remaining off...the other way is the spray air cans..tip upside down and a freezing liquid comes out and instantly freezes the gum and then pick it off with a credit card....
I have never tried the can freeze on leather so I can not say if it will stain or not...but never had a stain on any other material
Al
This is just one of the reasons that I love this place. Ideas like this are genius (air can upside down and a credit card). I wanna go do it and I don't even have stuck gum.
