For a coated car, 2 bucket maintenance wash, is there a preference between these 2? Or is another your flavor?
Agreed!Don’t bother with Bathe Essence. Regular bathe is better. Reset is even better.
What LSP is applied right nowThanks All. Reset will be on order later today.
For clarification - my car is coated and topped with a sealant. Does Reset affect the selalent?
Reset does degrade sealants faster than other soaps.
Ok, so I'm trying to wrap this up, but if it lessens/degrades the sealant, why use it as a maintenance wash? Now, I could see where it would be beneficial after each wash to take off the last detail spray, but most apply sealants eithers as a LSP or as a topper for the coatings.
If you want the true effects of your coating, don't top it. Or at least use the same type of spray product as your coating. Example would be, if your using CQuartz 3.0 than top with Elixir.
Why top with a completely different product? If you like your topper so mush, why not use it also as a base coat?
