Gyeon One makes a difference!
Elliot@Autogeek
*15% Off Coupon Code ONE15 valid on in stock items. Not applicable on previously placed orders, RUPES Polisher and polisher kits, single Griot's Garage polisher units, Vapor Chief Vapor Steamers, and gift certificates. One coupon code per order.
*Free Shipping applies to orders over $50
with ground service within the 48 contiguous United States. Regular shipping charges apply to garage flooring and mats, air compressors, and carpet extractors as noted on those products. Regular expedited charges apply.
GYEON Q2 One Complete How-To
by Jeff McEachran, the GYEON USA National Brand Manager
GYEON quartz Q2 ONE is the perfect upgrade from your traditional wax or sealant. It is a true Ceramic (SiO2) Coating that is very easy to apply, delivers tons of gloss, will last at least 12 months, and provide real protection from UV and environmental damage while making regular maintenance washing fast and easy.
So why is a Ceramic Coating like Q2 ONE better than the wax or sealant you are using now? Great question. When we are applying protection to paint (wax, sealant, or coating) we are applying a layer of film and asking it to protect the paint underneath from the exposure to the outside world. Where coatings win over a wax or sealant is based on the chemistry of the layer of film over the paint, in Q2 ONE’s case it is SiO2. This layer has the ability to bond to the paints surface for a much longer time span than a wax or sealant. This layer of SiO2 also has a higher capability of withstanding degradation from UV and environmental impact.
It is also highly repellent, and will make regular maintenance washing of the vehicle quick and easy.
So how do we successfully apply GYEON quartz Q2 ONE?
The first step in any coating application should be a thorough decontamination or degreasing of the surface. Use GYEON quartz Q2M Prep as a pre coating wipe down to remove all oils or lubricants from the previous detailing step. It is very important to have a perfectly clean paint surface so the coating can bond directly and perform its best.
Once the paint has been prepped, it is time to apply Q2 ONE. Make sure you are working on a cool surface and out of direct sunlight. A hot paint surface or a surface under direct sunlight will cause the solvent carriers of the coating to evaporate too quickly. Place the included Suede Applicator over the Foam Block as shown. Apply a moderate amount of Q2 ONE in a straight line, top to bottom, on the applicator. Always start with less product than you think you’ll need and increase if needed.
Choose a shoulder width area to work with. Apply Q2 ONE in a cross hatch and overlapping pattern to ensure even coverage. I like to work top to bottom, and then left to right when applying.
We do not let coatings sit on the surface for long periods of time as you would a wax or sealant. We want to remove the excess material within 15-30 seconds and before it starts to dry. Use a brand new and plush microfiber towel like the GYEON quartz Q2M Soft Wipe to effectively absorb excess material.The quality of the towel is very important. Also, use a hand held light to make sure you are removing all of the excess product from the surface to avoid and streaks or high spots.
Work your way around the paint, one shoulder width area at a time, making sure to remove all excess product effectively. Then sit back and enjoy!
GYEON Q2 One 50 ml.
Our Price: $84.99
GYEON Q2 One Prep & Coat XL Combo
Our Price: $128.95
Sale price: $99.99
GYEON Q2 One 30 ml.
Our Price: $64.99
GYEON Q2 One Prep & Coat Combo
Our Price: $101.95
Sale price: $85.00
GYEON Complete Coating Kit
Retail Value: $285.90
Our Price: $239.99
