Gyeon Q2 Prime BONUS
Elliot@Autogeek
GYEON Prime - Big Time Gloss in a Little Bottle
GYEON Q2 Prime is a high quality Quartz Coating based on silicon dioxide (SiO2) technology. It delivers an extreme level of gloss, 9h hardness, exceptional resistance to water spots, and true protection from harmful environmental and chemical contaminants. Q2 Prime is designed to be applied in a single layer, however can be layered for increased durability up to 3 layers maximum.
What's included in the GYEON Q2 Prime kit?
• Q2 Prime 50ml. Bottle
• Q2M Cure 100ml Maintenance Spray
• GYEON Foam Applicator Block
• 5 qty. GYEON Suede Applicators
• Glass Dropper
• Protective Mask
• GYEON Instruction Sheet
GYEON Q2 Prime How-To:
Like any Quartz Coating, proper prep of the surface is key. You want to make sure the paint is completely free of any polishing oils or lubricants from any soaps.We want a pure interaction between the paint and the coating. GYEON Q2M Prep should always be used, and if heavy polishing with an oily product has taken place then a wash with a heavy degreaser is recommended.
Once the paint is clean it is time to coat!
Apply 4-6 drops of Q2 Prime on to your Foam Block and Suede Applicator combo. Work a small area at a time, about a 2’ x 2’ section. Flash times (when the coating is ready to be removed) will vary depending on temperature and humidity.Remove the coating sooner than later until you find the sweet spot, usually right around 20-30 seconds.
Thorough removal of Q2 Prime is very important. Any product left on the surface will harden and require polishing to remove. Use brand new and high quality microfiber towels for removal. Fold the towels in to a perfect square, giving you 8 fresh sides to work with as needed.It is also a good idea to use a handheld swirl finder light during removal. This way you can play with the angle of the light and make sure you have all excess coating off of the surface.
If you are going to layer Q2 Prime, wait at least 1 hour between layers. The coating should remain perfectly dry for the first 24 hours and not washed with any detergents for the first 7 days.
Time to sit back and enjoy!
Limited Time Only
Receive a 400 ml. GYEON Q2M Bathe+ Plus FREE with your purchase of the GYEON Q2 Prime 50 ml. Kit!
[TD="align: center"]
[/TD]
[TD="align: center"] GYEON Q2M Bathe+ Plus
Q²M Bathe+ is perfectly safe on all surfaces including paint, rims, glass and plastic. It will add instant protection to bare surfaces or boost the base quartz coating you already have on these surfaces. It can also be used over existing natural waxes or sealants improving their durability and gloss. The active SIO2 ingredient adds real protection that you can see every time you wash, unlike many so called ‘wash and wax’ shampoos, you are left with added hydrophobicity and self-cleaning ability that keeps your car actively cleaner for longer.
[/TD]
This is the perfect weekly wash maintenance product to get the most out of your Q2 Prime Coating. Mix Q2M Bathe+ in to your wash bucket as noted on the bottle. Wash a small area at a time, the hood for example, and then rinse immediately. Q2M Bathe does contain SiO2 which must not be allowed to dry on the surface. Work your way around the car, one section at a time, rinsing the area immediately after washing and you’ll keep the hydrophobic properties and gloss of the coating at its highest level.
$21.99 Retail Value
PLUS - All Orders* Ship For Just $5.95!
GYEON Prime 50 ml FREE BONUS!
Our Price: $89.99
For a limited time only, receive the GYEON Q2M Bathe + Plus - 400 ml FREE with your purchase!
$21.99 value!
