DFB
- Aug 12, 2019
- 4,650
- 2,459
Gyeon Q2 Quickview
Gyeon Q2 Quick View was released earlier in 2021 and is designed to provide a hydrophobic coating to all exterior glass surfaces. Quick View has a life expectancy of approximately 6-months and also has the ability to repel contamination.
Like all Gyeon products, Quick View is presented in fresh packaging. While packaging is not an indicator of a products performance, there is no denying Gyeon have nailed the branding and bottle design of their products.
Gyeon recommend decontaminating glass prior to application with the use of a clay bar, although you could also polish the glass if required to. In my case, I used a clay block with Meguiar's Final Inspection as the lubricant.
Once clayed, I wiped the glass clear of the lubricant and then followed up with CarPro Eraser.
With the glass prepped, it was time for the Quick View. The main selling point for this product in my mind is the integrated applicator. First step is to squeeze the bottle to soak the felt pad.
Quick view is applied by working the applicator across the glass in circular motions, squeezing the bottle to release more product as required.
After letting sit for 5 minutes or so, you then wipe the product off the glass with a damp microfiber.
The application process of Quick View makes it a very simply and easy way to protect glass.
