Jeff at Gyeon
- Aug 15, 2016
- 83
What's Up Guys and Gals!!!
I want to talk about one of my favorite products in the GYEON Quartz line up, Q2M WetCoat. This product is extremely versatile. It can be used on coated or non coated cars, even over other waxes and sealants. My favorite part, it's safe on every exterior surface of the vehicle and performs fantastically. All of my vehicles are Coated, so I use Q2M WetCoat as a top up every month or two to keep my GYEON Coating performing at its absolute best. It can also be used as a spray sealant over non coated cars and surfaces.
Q2M WetCoat Offers:
- Instant Hydrophobicity
- Great Self Cleaning Properties
- Intense Gloss to Painted Surfaces
- Can be Applied to all Exterior Surfaces of the Car
So how do you use it?
1. Wash the vehicle as you normally would. You want a clean surface to work with.
2. Rinse the vehicle as you normally would, leaving it nice and wet for the WetCoat application.
3. As its name suggests, WetCoat is designed to be applied to a WET surface.
4. Pick an area to start with, I usually choose the hood. You want to apply wet coat to small areas at a time, not the entire car. And always in the shade and on to a cool surface.
5. A little bit goes a long way. Spray 5-6 sprays evenly over the hood.
6. Immediately spray the applied area with a high pressure blast. I like to work the product around a bit, and dance it over the area.
7. You will see the water beading increase immediately.
8. Make sure the applied area is rinsed completely, and move on to the next (ie: fender)
9. Make sure the entire vehicle stays nice and wet during application. I constantly re wet the area I have just worked on, just to make sure no WetCoat has run off the far side of the car and is drying anywhere. If WetCoat is allowed to dry on the car, it will streak and is a real pain to remove. Remember, is does contain small amounts of active SiO2.
10. Work your way around the car one area at a time. Use it on the glass, chrome, plastics, wheels, etc.
11. WetCoat is designed to last up to 12 weeks, but can be used as often as you like.
For me, Q2M WetCoat is the fastest and easiest way to introduce small elements of SiO2 designed as a top up to any vehicle. This can also be done with Bathe+ and Cure.
Scroll down past the pictures to the link for the AutoGeek GYEON Q2M WetCoat Page, there may just be a deal waiting for you!
Here's a great Facebook video of WetCoat in action:
https://www.facebook.com/gyeonquartzofficial/videos/1925509911012471/
Click HERE for the GYEON WetCoat 500ml Product Listing
Click HERE for the GYEON Wash Kit Package Listing
Thanks for reading!!
Q2M WetCoat Offers:
