gyeon wet coat
wkndwarrior89
Has anyone tried using gyeon wet coat or even hydrolite as a solo lsp? If so how did it hold up durability wise
I use the latter option although from concentrate. Currently I have mine mixed at a stronger ratio 1:3 and have no problems getting 3 months durability.
I use in conjuction with hi temp wax.apply hi temp and when removing hitemp spritz some wet coat on panel and wipe off both products together,,amazing results with extreme hydrophobic.
What about upgp+? Would that be better solo? Read good things about it but heard the New formula isn't as good as the original
Wet Coat Essence can be diluted from 5:1 up to 15:1. I contacted Gyeon because I was curious what the equivalent ratio of Essence would be to that of the RTU Wet Coat. The orange regular bottle would be the same as Essence diluted 10:1. Just an FYI.
