Which products work well at extending and maintaining Gyeon Wetcoat? I'm afraid that conventional QDs and QWs will affect the water behavior.
Can Wetcoat be diluted so that it can be used as a hand applied WOWO?
Just using as standalone.
If useing as drying aid they recommend to dilute it at 1:2 useing destilled water. N914 is great as not leaving anything behind but if you want some sio2 to waterless wash or rinseless wash get carpro Ech2o.
I think that they have tested to dry applying Wet Coat. Think they didn't get it to work out as well. I have read about a hybrid method of dry and wet application when useing gyeon wet coat and did it twice. After the final rinse of the car soap you leave it wet as useally. Then use a damp mf towel or sponge and spritz this 1 time and then 2 spritz on the panel. Start at where you sprayed at the panel and spread it out to the whole panel and then pressure wash it off. This gave me to use less product and have had no problem with streaking or that some parts is failing before others. That I have read and heard about have happen to some. The longevity has been 7 weeks with no degrade of it which I think is great in the climate environment I live in. This is with none washing between so no topping. It was some detailer in UK that came up with this application. So no more than 2-4 sprays depending on the size of the panel. Just wring out the application media when saturated and use nitrile gloves.
Just did a wash after 2 weeks. Noticeable degradation in beading and sheeting of water, even after a wash to remove contaminates. I followed up with more WC but this time topped with Ceramic Detailer. A bit disappointed in durability, but I go back to the point that if you wash your car every 2 weeks or so, does durability matter? It's so easy to apply and air drying is simple once you treat the paint with WC.
I used Bathe Essence today for the first time. Weird soap. Very watery with minimal suds. I guess it worked ok because the truck came out great. It wasn't super dirty though to really judge the cleaning properties of Bathe.
I don't expect months out of the spray/rinse products. If I can get 2 months out of it, I'd be content. You're really paying for the simplicity and ease of use with a product like Wet Coat.
*I'm curious if Gyeon Cure is a better topper for Wet Coat than Ceramic Detailer......
I wouldn't rely on Wet Coat or similar product to get through a normal winter. Can Coat + Wet Coat is likely needed.
ECH2O is a nice product but seems kind of steaky.
