Well what can I say but apparantly I booboo'd. My car had a couple of stray wet sending marks from the last time it was at a body shop. I purchased some Meguiers Ultimate compund to test it out. I applied by hand with a microfiber pad and removed with a micro fiber pad. It took out most of the scratches (I imagine they were stray 2000 grit), but some of the deeper ones stayed.
Problem now is that there are slight holograms from when it was applied. (by hand as these were crevices and corners) So the question is how to fix by hand? A different applying and removing technique with the same Ultimate compound, or try something less abrasive like a glaze? Which coincidentally will also be applied by hand as I do not own a good DA.
