Countersteer46
- Apr 12, 2013
- 18
Can someone explain the difference between hand sanding and machine sanding? I've heard that you use machine sanding for coarser grits and hand sanding for finer grit. I've also been told the exact opposite, you hand sand with coarse grits and machine sand with finer grits.
Secondly, what's the difference between wet and dry sanding? I've been told wet sanding just makes your paper last longer.
Finally, if I want to take out orange peel, how high a grit do I finish with? I've been told anywhere from 2000 to 5000 and I'm frustrated with the inconsistent answers I'm getting.
