Will Iron X remove hard water spots? I have tried Chemical Guys, Meguiars and Mothers and none of them touch the hard water spots on my truck
It's a white truck and it's difficult to get a good picture. All the photos you have posted is what I have.
Hi Mike,
First, thanks for all you do!
Was wondering if your class will be addressing working on single-stage paint, as I have some water spots on red paint I’d like to address. Not sure of the origin of the water spots, as I just got the car.
Thanks!
Perhaps #7 show car glaze I is in order, does that have any abrading qualities or is that something that will provide high shine while living with the spots (which I can accept versus primer and steel)?
Hi Mike,
Thanks!
Sorry, been away for a while.
So for using the pad, would a white thin pro pad be too much. The black and red thin pro pads have no cutting from what I understand.
The spots aren’t that bad, but it’s one of those “I know it’s there” issues.
Thanks!
I used the GG9 polisher (with 5 inch vented GG plate and 5.5 inch pads) and tried a test spot with the white LC ThinPro Pads.
As I saw a recommendation for an AIO since we were dealing with single stage paint (more about that later...) I went with HD Speed.
Test spot turned out pretty good, so proceeded cautiously over the rest of the car (1998 3000GT I just acquired a mointh and a half ago).
As I worked my way around the car, it was going well, as the hood came out quite nice. Mover to the doors, and all was well as the HD Speed was easy to work with for this inexperienced polishing person.
Since I have shade/sun challenges behind the house, I decided to work on the roof of the car, which rendered more paint than the other areas.
It polished/AIO'ed up nice, but seeing that much paint was a bit scary (to be honest, If I had started there, I probably would have stopped for fear of not having 25 white ThinPro pads).
Continued with the back of the car, which also rendered more paint than expected but was workable, as I followed Mike's advice in other articles about having a good amount of pads.
Had 10 of the 5.5 inch pads to start, and wound up going through 9 of them. Use the GG 6 and 3 inch ThinPro pads for the smaller areas where I could.
I do have an issue with getting the pads clean after using HD Speed, as there appears to be some permanent staining (tried WG Pad Worx, Blackfire Pad Cleaner, BlackFire APC with a pad brush to no avail).
Overall, the AIO left some expected imperfections, but considering the inconsistent paint (some areas seemed to behave like single stage, some like clear coat) 33I am happy with how it looks.
The water spots are done, save for a couple in different areas of the vehicle.
Here are some of the pictures (resized to get them up on the site):
I do want to thank Mike for his guidance/advice, as it helped remove some of the concern I had on doing this car as my first with the GG9 and ThinPro pads.
I know it can probably be better, but I feel like I've done well without removing too much paint (I have no ideas of the paint history of the car, and don't have a paint thickness gauge...yet).
If anyone has experience with getting HD Speed staining out of the ThinPro pads, that'd be great. If not, guess I'll have to order more for my other cars, and save these for this car and AIO).
Also, thanks to the other forum members who posted questions and advice which made things easier and helped quell some fears I had in doing this.
Thanks!
