I know that headlight eventually haze over when UV light overcome the protection coating that comes with the car. I was trying to find a way to prevent or delay the inevitable yellowing of the lens. Supposedly, the actual coating used in headlight lens are a compound that is cured using UV and is impractical to apply at home. The home alternative appears to be:
1. Some sort of film like Xpel. Most people appear to have good luck with this method and tend to be pretty permanent. The problem is that headlight appears to be a bubble shape and would be really difficult to apply the film over.
2. Headlight cover. People who tried this indicated that a ring develops around the outer-edge of the light where it is not covered by the cover.
3. Clearcoat - spray a clear coat over the light to recreate the protection layer. The 2K one will last longer but require a carbon respirator. The 1k won't last more than a few years.
4. Polymer product like Meguiar's G17804 Keep Clear Headlight Coating, which only last a few months and have to be reapply. This seems tedious, since it's a spray which means I have to mask the light to prevent overspray.
I am thinking of hiring a detailer to put on the film, other post suggested a stronger coating like opti-clear, but different poster seems to have different opinion on how long it last.
The other possibility is to wax the lens. I was wondering if that actually works?
