Hello everyone. My wife and I have a 2012 Nissan Versa Hatchback. The right front headlight assembly has developed moisture inside it. We found a hairline crack in the size. Can this be repaired as a short fix? Can we remove the assembly, dry it with a hair dryer to remove moisture, and them run a flat bead of clear rtv to close the hairline crack? This would be tempoary. That way my wife has clear headlights until the assembly can be replaced. Would this work? What would you suggest?
