Headlight Repair
Superman0440
Hello Autogeek today I want to repair my headlights:
I'm not using a headlight repair kit I want to try it Using sandpaper.....is there an how to topic I can get a link to or step by step instructions on how to repair them
Hello and welcome to AGO!
For headlights depending on how bad they are they could need sanded but using the proper tools and technique is key.
Do you have any photos you can share of you headlights that you want to fix?
Here is a an article you will want to read through to get an understanding of the process and the tools used.
http://www.autogeekonline.net/forum...sander-takes-work-out-sanding-headlights.html
-tape off edges of car as to not sand the paint
-clean headlights with either QD, WW, RW, etc..
-1500, 2500, and if you want 3500
-wash lens again
-m105 with semi agressive pad (or equivalent)
-m205 with polishing pad (or equivalent)
-seal or coat
Thanks for the fast reply ...
I'm sorry I do not have pics, I'm at work..
So if the lens aren't that bad I should use a higher grit sandpaper like 3000
And thanks for the link
-wash lens again
-seal or coat
I'm very new what's the acronyms for qd or ww
Also can I seal with black light
Without seeing a pic, it's kind of hard to judge what grit you need to start at, etc.
