Headlight Restoration: BMW 520
fishbonezken
A very common sight on many older cars in Malaysia is the yellowing of headlights. We have an equatorial climate here and the heat is at its maximum all year round, this prolonged exposure to heat and UV rays from the sun accelerates the oxidation of plastic headlights. Causing them to yellow, fade, and when looked closely, the plastic is actually cracking.
On the headlights of this BMW 520, it appeared that one of the headlights has been sanded, I guess the technician didn't know how to follow up properly to restore them. So the sanding marks were left behind, and actually looked worse than parts that were not sanded.
When looked up close, the plastic has what I like to call 'Micro-Cracks', from afar they appear to be a yellow film, up close, the plastic is cracking on the surface. When left for too long, the cracks will spread and eventually become deeper, leaving a permanent line on the plastic that even sanding, cannot fully remove.
Most of the time, polishing with a wool/foam pad with a rotating polisher(drill/rotary buffer), can make most lenses clear. Unfortunately, that was not to be in this case.
As seen from the photos above, polishing definitely cleared up the lens, but the results are still not optimal as the micro-cracks are still there and the wool pad is not skimming the surface of the plastic deep enough. Hence, it has to be sanded down.
I expected this job to be done in 3 hours but it took me 6 hours in total. I don't have any process shots as I was pressed for time and the owner is waiting for me to get it done. I also had to redo some portions as I noticed there was still some micro-cracks after final polishing with the foam pad.
Process as below:
(1) Two to three layers of tape around the headlights. This is because the out-most layer will start to lose its adhesiveness and peel when soapy water touches it during the wet-sanding process.
(2) Hand sanded with 400 grit > 600 grit > 800 grit > 1000 grit > 1200 grit > 1500 grit > 2000 grit.
(3) Machine polished with 4" Surbuf Pad and Meguiar's #105 Ultra Cut Compound via rotary @ 1200-1500 RPM
(4) Machine polished with 4" Lake Country CCS Orange pad and Meguiar's #105 Ultra Cut Compound via rotary @ 1200-1500 RPM
(5) Machine polished with 4" Lake Country CCS White pad and Meguiar's #205 Ultra Finishing Polish via rotary @ 1200-1500 RPM
(6) Wiped down with Isopropyl Alcohol (diluted 1:1)
(7) Surface dried with hairdryer to remove moisture.
(8) GTechniq C1 Crystal Lacquer is used to coat the surface to prevent re-yellowing.
(9) Dried again with hairdryer to accelerate curing.
Results on the edges is still a little compromised but way better compared to before.
On the larger areas, looks perfect from far and even 10 cm away. When looked closely, some gouges in the plastic is still there. I think a more uniform finish can be achieved with machine sanding compared to hand sanding.
Finally, some before and afters.
Without flash:
With flash:
After shots:
Thanks for looking at my humble work. :)
Unfortunately in today's economy those pictures are only worth 500 words, but what amazing shots..
Great Job
Man, those headlights look great.....now time to get the swirls out of the hood
Humble? More like AWESOME!!!!
Thanks! :)
DUDE!! Those Macro shots are insane!!
Thank you!
Great Job
Haha! Thanks.
you are a true Professonal
Just an enthusiast and still learning everyday :)
Yes the car will need a full de-swirling soon, it's such an eye sore.
NICE work!!!
Thank you!
Awesome photography and awesome work!:dblthumb2:
nice, but any protection will be useless unless u use something like opti-coat or paint clear-coat cause you sanded off the factory UV coating.
AMAZING photos! And great job on the headlights.
Qaz393, that's not true at all...the factory coating needs to be FULLY removed before you apply any kind of new protection what-so-ever. And it doesn't matter what you use on plastic headlamp lenses...the hazing WILL come back, period. It's just a matter of time. Whether you use a standard automotive paint sealant, Spar Urethane, clear coat or even Opti-coat...they will eventually cloud back up. I've had to repair previously "fixed" headlights before. I've had to remove clearcoats, the infamous boxed headlight repair sand scratches and pretty much every other kind of "protection" you can put on headlights. They all brown back up again.
I've done my own headlights on my 1992 BMW 325i twice. You couldn't see through the lenses at all before I started. The first time, I did them with wet-sanding down to a new surface layer, polishing them out and then just sealing with Poorboys Paint sealant and they lasted 2 years before I had to do them again. And my car doesn't know what the inside of a garage even looks like. The second time, I polished them out and then applied spar urethane and they're still clear going on a year now, though just a tad brown at certain angles, but that's from the tint of the spar. One day I'll order some opti-coat since it's clear and I like to polish my headlight repairs completely out before applying protection.
Awesome! Normally I wouldn't create a zombie thread, but your excellent photos representing the tiny cracks deserve seeing again. :)
