Headlights - Auto Geek Online Auto Detailing Forum
Check this out! Art posted where you can get all of the supplies! It will cost you 20 dollars a car and you can do others people and make some $
I did this and worked out good you can also do it by machine
Step 1: Sand with 500 Grit until the lens is opaque white. This is the most important step because the more even your sanding, the better your overall results will be. Wipe lens
Step 2: Sand with 800 Grit and sand as your did the first time. This step is to begin refining larger sanding marks
Step 3: Wet-Sand with 1200 Grit. Fill a spray bottle and generously apply over the area to be sanded. Sand as you did the first two steps. You will notice that the lens is beginning to look clearer. Continue wet-sanding until all previous sanding marks have dissapeared.
Step 4: Wet-Sand with 3000 Grit. Sand as you did with all previous steps. At this point, all of your previous sanding marks have been refined and its time to bring out the polisher. <font color="red">*If you don't have a polisher, I recommend buying a white Euro CCS Hand Polishing Pad from AG.
Step 5: Compound the headlights.
<font color="red">*Wolfgang Compound, Menzerna Compound, and Meguiars Compound are most commonly used amongst people on the forum with great results.
Step 6: Polish with a fine polish.
Step 7: Seal Them Up. Opti-Lens is a great choice as its designed to be permanent. DP Headlight Coating is a fairly new product made by the good folks at Autogeek so it's also a solid option.
<font color="red">IF YOU DONT WANT TO SAND, DP MAKES A HEADLIGHT RESTORATION KIT BUT THIS REQUIRES A DRILL. THIS IS A MUCH FASTER OPTION AND HAS YIELDED VERY SIMILIAR RESULTS TO SANDING.
Hope this helps,
Brian
