I sand and polish then seal. I need to find out if this is a good UV seal ? they say it will hold up for 2yr.I wouldn't use a coating on headlights,if they can be sanded and polished that would be a longevity solution ,if the cloudiness is on the inside maybe a coated would be a last attempt for somekind of improvement.
I have, just yesterday. It has good reviews on Amazon. It is self leveling. Needs UV light to cure. I'm so new with it so not sure about my longevity. I have a pic of a light I pulled from a junk yard and restore, then sealed it with it. I'm busy with homework (College) right now but I'll try and post a photo bucket pic in a day or sooner.
DeansDetailing, how long does it take to dry? Is it like a paint like the 4Everclear or a wipe on/wipe off substance? Man is it pricey though...
Rbos:
-cleaned it with glass cleaner
-Had to get out a single deep scratch by hand with 320 grit
-3M 500 discs on drill (dry)
-3M 800 discs on drill (dry)
-3M Super Duty Rubbing Compound on wool pad
-3M Trizact 3000 grit
-3M scratch remover
-Glass Cleaner, then dry it with towels
-4Everclear.
