Radster1986
- Oct 19, 2012
- 63
I recently took my car into have the sunroof motor replaced, in the process I am assuming some of the black grease that is on the guides got onto my headliner. There is a small black dot, and a few very light fingerprint marks here and there. Rather than have the dealership clean it, I thought it would be much better to do it myself given that I will be alot more caring with the process.
My question lies here...
The headliner is a weird smooth texture that is almost a semi gloss when you look at it from an angle, but has a pattern on it like small circles/ocatagons. The car is a KIA, so I know they skimp somewhere on the interior parts. I had another KIA previously with the same sort of headliner, that was ruined by a "interior restoration professional" using a microfiber and cleaner and rubbed the pattern until it was nothing but flat and full of fuzzballs completely ruining it.
What can I use that will get rid of the grease marks without effecting the headliner material/texture? I plan on using a blotting motion rather than a rubbing or scrubbing. I have always had good luck with oxi clean on anything in my house that has had heavy grease staining on it, but I also read somewhere that woolite is about as safe as you can get. Thoughts? Opinions? Thanks in advance!
P.S. Can post a picture, if needed.
