Help, chrome or aluminum exterior trim accents showing oxidation
ropese
Hello, what used to be the shinny trim around the windows and other exterior frame of my 2019 Infiniti has cloudy spots all over. I believe this is oxidation, right? How can I remove the oxidation and restore the shine? Is it something a detailer or body shop can remove? Thank you
GYEON Q2 TRIM.
Also, look into wrapping it. Will look way better. I'm biased though.
Sent from my SM-G988U using Tapatalk
Thanks for the suggestion. It’s a lease vehicle. I’m just looking to remove the oxidation at this time.
Then just clean and apply Q2 Trim. It's common on anodized aluminum. Here's a before and after of a VW (it's very common on German brands)
Keep in mind, mine was a lease too. Doesn't take much $ to wrap the trim. Worth it if it's not too far along into your lease. YMMV.
I polished my metal exhaust with Pinnacle Exhaust Cleaner polish and a Lake Country Exhaust Polishing Pad and the exhaust cleaned up nicely. Then I put Collinite 850 metal polish on and nothing sticks to the exhaust,I just wipe the shrouds with a towel during the wash and the exhaust tips look as good as new. So you could consider Collinite 850 too.
