After doing a test spot, how would I know if the paint is hard or soft?
Is 'hard' interpreted as being hard to remove defects and rids?
Still learning here and appreciate your info so far![]()
If you have not checked it out already I would recommend checking out the polish/compound comparison chart and the paint hardness chart. You can find them under product charts and graphs.
^There are many characteristics that will help you to determine if a vehicle has hard or soft paint.After doing a test spot, how would I know if the paint is hard or soft?
^Basically, yes.I think what everyone is trying to say is not to worry as much about whether the paint is hard or soft, but rather rely on your test spot(s) using least aggressive method and progressing from there until you achieve your desired results. I think if you take that approach on every job, you won't have to worry about the hardness/softness of the paint. Hope that helps. :xyxthumbs:
If you can mar the paint with touching it with your hand I'd say it's soft.
First, you need to establish your control variables... these are things that will not change and will help you to compare the paint to others that you have worked on. For me, I tend to begin my test spots with something like Meguiar's M205 and a White 5.5" LC Polishing Pad. I also try to use the same machine, machine speed, arm speed, and pressure.
Essentially, make as many of the variables constant so that the only thing you are measuring is how the paint reacts to that process... make sense?
So once you have your product/pad/technique figured out, here is what you are looking for to help determine paint hardness.
Paint is hardly improved - most swirls and scratches remain. This would indicate harder paint. A more aggressive pad and product would most likely be needed to produce the results you are looking for.
Paint is somewhat improved - 50% of swirls are gone, but all deeper defects remain. I would call this "moderately hard". Depending on the level of correction you are seeking, you may only need to use either a more aggressive product or a more aggressive pad, but maybe not both. If you are looking to eliminate the majority of deeper defects, you may need to increase both product and pad aggressiveness.
Paint is nicely improved - Light swirls are gone, but deeper defects (RIDS) remain. This would indicate average paint to me. I find that M205 + White polishing pad should be able to remove swirls, but not necessarily RIDS. If you want a bit more correction, stepping up to an orange light cutting pad is a good option at this point. It is also important to also make sure the paint is finishing down well without marring.
Paint is very much improved - 90% correction, swirls are gone and only the deepest of RIDS remain. If you are getting this type of correction with M205 + white pad, I would assume you are working on soft paint. At this point, you may notice micro marring (especially on darker colors). If this is the case, you may want to step down to a black finishing pad and see if you are able to achieve similar cutting results, but finish down better.
*This is just my sort of thought process as I am working on test spots for a single polishing step... ie a job where I will ONLY be polishing once, not compound + polish or polish + jeweling. If you have the intentions of compounding first to remove heavier defects, your goals of the test spots will change. For instance, I would be looking for more correction of deeper defects, and I would not necessarily be concerned with marring since I would be following up with a polishing process to refine the haze left by compounding.
^Basically, yes.
I would not say it is always best to start with "the very least aggressive method". For instance, I doubt anyone here starts their test spots with SF4500 and a Crimson Ultra Fine Finishing Pad for each car? However, it is certainly not smart to jump straight to a cutting pad and compound even if you are working on paint in very poor shape. You might be surprised at what you can achieve with a medium or fine polish on softer paint... even if it looks completely trashed to begin with. That is why I typically start with something relatively non-aggressive and that works well on most cars like the M205 + white pad.
Now, there are certainly times where experience plays a factor in my test spots. For instance, having worked on many vehicles, I do know when some tend to be softer. In these instances, like most jet black paints, I will often start with a less aggressive pad and/or product.
-Zach
