Help me remove light swirls
stangyellow
I have an '02 Mustang GT, Zinc Yellow (very bright) and it has small swirls. I detailed the car 2 summers ago using Meguiar's 205, and the car came out amazing. Since then the car has shown some very small swirls. My question is, can i use Meg's #3 Glaze and have it be effective in removing these swirls? I don't want to go too aggressive on such a small defect. Any other suggestions? Thanks.
#3 is non-abrasive, any cutting action would be from your application material and process, for example applying it with a wool pad on a rotary buffer might remove defects but the wool fibers that make up the wool pad would be the abrasive and the oils in the #3 would simply be lubricating the surface.
Use the M205 again, it's a very light cleaner/polish.
Try Menzerna Micro Polish! I did last night and it's like 205 on Steroids!
Awesome polish plus more correction ability
