Help! My first detail project, and its a 26ft boat!
Dan NZ
Hello all! Dan here from NZ
This is my first post on the forum after reading numerous articles… Wow what a great resource you have here! I am about to (attempt to) start my first detailing project which will be the gelcoat of my recently acquired 2005 26ft Grady White boat. I will try to provide as much information as I can right up front.
Objective:
My main goal is to measure my thoughts against your collective experience. I need to balance my expectations and budget. I have done a lot of research but I am yet to pull the trigger on a polishing tool, pads and compounds. I do not have access to all the great stuff you have in America, so I will list some products that I can access here to help narrow this down.
Expectations:
I am never one to sell myself short, however I am not excepting the mirror like results you guys manage to get. If I achieve such results I will be blown away, but my primary goal is to obtain a good level of shine and protect my investment going forward.
Budget:
Without going too far down the rabbit hole, I would like to tackle this project for about half the price I would have to pay to have it done. I am time rich during this COVID 19 lockdown, but I have tightened up on my spending as a furloughed Airline Pilot (at least for the time being). I figure the job is about $1500 NZD (and that might be a gross error), so my budget is $750 NZD… About $450 USD
The boat:
She a 26ft Grady White that has been slipped in South Florida since 2005, before being imported to NZ 2 months ago. While the hull still shows some wax shine, the topsides visibly bare the aftermath of 15 years in the Florida sun. Unfortunately, down here in NZ we have very high UV levels so things will only get worse if not addressed! The boat will be dry stacked without a cover 4 levels up where I can’t get to her and exposed to the elements.
The photos I have added were tricky to take and may not properly convey the condition of the gel. The gel is oxidised to the point where it will leave a chalky residue on your fingers when rubbed. I have done some testing and it comes up pretty well after a couple of passes with 2000 grit wet (by hand), then compounded (by hand) and waxed. 2000 Grit is the finest grade paper I can readily get my hands on here in NZ. I am not sure how far I can wet sand/compound before I start cutting though the gel and so I feel that getting the gel to a stage where I can maintain it might be better than getting it back to new. How long is a piece of string, right?!
Wet sanded and compounded. Tape to assist focus
Oxidized gel
The shiny test area has been wet sanded, compounded and waxed all by hand
Tools:
I have used a Makita rotary buffer in the past and found it a little intimidating. I did not feel that I had great control, or much accuracy. I have a random orbit sander (Bosch Gex 125-150 AVE) however that bogs down and stops spinning with polishing pads. It is a sander with a limited 4mm throw, however I feel this demonstrates the limitations of the random orbital concept. I though a forced rotation DA might be the best compromise and can purchase a Makita PO5000C for NZ$390 (US$230). I have read Mike Phillips review and I feel this may be the best bang for my buck. I understand that the free spinning mode is weak, but the forced rotation mode is effective. I cannot justify over NZ$1000 for tools like the Rupes Mille for example. If anyone has experience, do you think the Makita would cut the oxide with the correct pad and compound? If wet sanding is the best starting point, could this tool buff out the 2000 grit scratches that seem to come out with 3M compound by hand?
Pads:
Lake Country, Rupes and Chemical Guys are the “best” pads I can readily find in NZ that you will have experience with. I am leaning towards Lake Country as there are numerous good reviews. These pads are double what you pay in the US (one orange 5.5 LC pad is about $14 USD here in NZ) so I want to buy the right pads, and the right number of pads (as best as I can). Do the LC pads play well with the Makita PO5000c? Can you recommend what colour pads for the gel (maybe in three steps… Oxide removal/polish/wax), and what pad/s I should use for the milky Isinglass?
Compounds:
Again, section is a little bit limited but the common ones you know like Chemical Guys, 3M, Menzerna, Meguiars etc are available. I have not seen any “Marine 31” products here in NZ. The available compounds are all about 2x the price as well. I currently have 16oz of 3M “Marine Compound and Finishing Material”. This stuff seems to dry out pretty quick but works ok when buffed by hand. Do I need to mist water when using it, or try a different product?
This is a long post so if you made it to the end, well done! Thanks in advance!!
Welcome to AutogeekOnline! :welcome:
We're about to shut down the shop as it's 5:00pm here. Been buffing on an all 2-door Dodge all day plus just finished a LIVE video on Facebook.
Autogeek - How to save time while you are polishing your car. | Facebook
Don't want to get divorced so I'm pushing away from the keyboard.
I'll do my best to help out tomorrow when I'm fresh.
Welcome to Autogeek Online my fellow Kiwi. :props:
Looks like you have quite the project on your hands there. You’re in the right place to find out everything about polishing Gel Coat - Mike Phillips is “The Man” in that regard.
Don’t sell our little country out too short though - most high quality brands can be found here no doubt. Personally - I’m a fan of Lake Country pads, so I’m sure Sam at UCC will have what you need. I just got a bunch of Marine 31 stuff in but no liquids I’m afraid. I would recommend giving Cam a shout at 3D.
Good to have you on board buddy. :xyxthumbs:
Aaryn NZ. :dblthumb2:
Wow Mike, I did not expect such a quick reply from the top man! I am not sure how you make time for the number of responses and the detail you generate.... Really amazing! No hurry, I am locked in my house for another three weeks. Your opinion on the suitability of the Makita PO5000c for this project, pads and componds will be greatly appreciated! Basically, how should I spend my money haha?? I am sorry that I won't be able to make my initial purchase through you, however once I start flying to the USA again I wont forget your help!
Aaryn NZ, thanks for the welcome! It's funny how us 'kiwis' end up finding each other in forums all over the globe. Hope you are making the most of the lockdown :/
Thanks for the tips! I have had the UCC website open for a couple of days now, it looks like it will be the right place to go to kick-start my detailing toolkit. A big part of this is that I don't know what I don't know! I am not sure who sells what here in NZ, if there are better products or tools (proportional to my budget) that I have never heard of, or the right questions to ask to generate the advice I need!
Thanks guys, I look forward to learning a lot here and sharing my progress in time!
Dan
Dan NZ, you’re in the right place as far as information sharing is concerned. These folks here are considered family to me & I guarantee you won’t find any negative behaviour that is rife in other forms of Social Media - we are all here to help each other & yeah, even the Man himself & blessed to say - my good friend Mike Phillips will be more than happy to share his wealth of knowledge. :props:
Where about in the Land of the Long White Cloud are you buddy?
The Gradey White brand is a top shelf brand of hulls. I would expect the gel-coat to be in the 25 mils to 30 mils range. Take 10 3M Post-it Notes and staple them together and then FEEL the thickness as well as look at it and this would be a general idea of 30 mils, as a 3M Post-it Note is around 3 mils. (I use this example in my boat detailing classes where we machine sand gel-coat)
Tools:
So just for the record, if I had a nickel for every time I was asked about using most wood sanders to polish paint, I'd be rich.
And as you have discovered, these types of sanders are USELESS to do any type of defect removal. They wont' even remove high quality holograms from a rotary without spending or wasting a lot of time, so might as well step up to the plate and get an orbital that CAN maintain pad rotation under pressure. Even the lowly Porter Cable 7424XP would be a great choice and serve you well for decades.
I'm guessing you Bosch looks like this?
I know a lot of guys like the Makita PO500C and for the price, you'll never experience pad stall so it will work. But for what it's worth, I have 6 or 7 of these out in the garage and I never use them. While the difference between 5mm and 8mm may seem like a small matter, 8mm trumps 5mm all day long when it comes to busting out a job. It's true, 5mm is more precise and that's due to the shorter stroke but once you learn the way of the BEAST you can make it do anything.
The Mille is like the Makita, they are both 5mm and thus both are precise and I know a lot of guys like both, if the Makita is available for your Electrical Power supply their in New Zealand, then it would be just as good an option as the Mille, in my hands-on experience.
Because you can use the Makita PO5000C in the gear-driven mode, you'll never have to "think" or "watch" for pad rotation, same for Mille, so "yes" they will both power through any kind of detail in my opinion, faster than any free-spinning tool.
If the BEAST is available in your Electrical Current, then I would get the BEAST. There's a reason you never see used units for sale and when you do, it's rare. Snap it up.
Pads:
You're going to use the rotary to cut out your sanding marks with a traditional wool pad. That's the BEST way to do it. So if you need to, start doing some push-ups in the morning and learn the way of the rotary buffer
After you cut out your sanding marks with the rotary, you're going to be left with HOLOGRAMS in the gel-coat. This is normal and to be expected. Despite what all the experts might say, rotary buffers inflict holograms. Sometimes you cannot see them but they are there. You want to remove them as these SCRATCHES multiple the surface area probably by 3 x and this leaves your gel-coat MORE OPEN to future oxidation.
Here's what I use and teach - RUPES COARSE BLUE FOAM CUTTING PADS on the BEAST with a quality compound (or polish), to remove the holograms. I've done this over and over and over again and it always works perfect on gel-coat. I also can't count how many people I shared this with over the years and they report the same thing. I.e. works perfect.
BUT - you MUST use a quality compound. The compound, or better said, the ABRASIVES are what touch the gel-coat first, the the pad, then the tool and you are the least important factor.
Usually a foam "polishing" pad with a fine cut polish that uses GREAT abrasive technology. If you use crap for abrasive technology you'll simply micro-mar the hell out of the Isinglass. I've polished out a lot of this material in my life and I'm very comfortable saying, I know what I'm talking about.
If you do start with a foam "polishing" pad, re-polish with a foam "finishing" pad for maximum clarity. Also - don't press to hard when polishing as you'll s-t-r-e-c-h the plastic or warp it.
Compounds:
Menzerna
See if you can get the FG 400. This works great for a compound and a polish for the gel-coat.
For the Isinglass, maybe try a fine cut polish in the Menzerna line.
I'll add some links to more info that will help you.
Thank you for joining the AGO forum to ask your questions. I'd also recommend asking anywhere else on the Interweb and compare the info you get to what you get here.
Dan NZ, you’re in the right place as far as information sharing is concerned. These folks here are considered family to me & I guarantee you won’t find any negative behavior that is rife in other forms of Social Media - we are all here to help each other & yeah, even the Man himself & blessed to say - my good friend Mike Phillips will be more than happy to share his wealth of knowledge. :props:
Thanks for endorsement and recommendation for this forum Aaryn. :)
To the OP, if you ever get a chance to take a detailing class from Aaryn, it will be worth the price in time and money saved as well as effort and energy.
Continued,
Here are some recent threads where I invested a lot of time sharing info, most of which will apply to exactly what you want to do.
I would strongly recommend taking some time to read through them, don't just scan them.
Polishing gelcoat makes it go dull - what am I doing wrong?
In post #18, here's a summary from the forum member after taking my advice to buff out his boat...
I ordered a couple of blue Rupes cutting pads and Mike kindly sent some Captains Compound for me to try with them.
the combination worked very well on both boats, which is cutting and polishing at the same time.
Under sunlight, I could see that the combination had worked well on the moderately oxidized surfaces and I couldn't see any swirl marks.
The holograms and fine scratches were removed nicely.
So in essence, the combination works well together, a successful result.
In addition, I didn't see any dulling/frosting with that annealed texture I mentioned before, the reason why this thread was started in the first place.
Here's another thread,
Gelcoat Polish Question - Removed swirls but also deep gloss? - Pics
Great info throughout, sorry to say no update from the forum member but I did just bump the thread and asked for an update.
And one more thing before I disappear to the garage to buff out a car....
If you're in driving distance of Aaryn and his shop, I'm sure Aaryn would be willing to let you try out his personal BEAST. He'd probably give you a few technique tips on using it to and let you run it over a car hood.
If this is possible, do it before you start spending money.
Plus Aaryn is a cool dude and will make a good resource for the future.
After trying the 5000C during your class, I really liked it and thought about getting one. But alas, I waited too long and it eventually was discontinued on AG. I wound up getting the G9 because it was a great value, has more power than my 7424XP, and I could use my store credit. I have not had a chance to use my new G9 yet, but I am expecting good things from it. I was just wondering which is the more important spec, 9mm vs. 5mm throw, or forced rotation vs. free spinning?
RamAirV1
Wow Mike, where to begin?! Thank you!!
I have been doing a lot of reading, all of the posts you have recommended and then some! I even read all 26 pages of the Makita/Mille/Flex post and came away with a good feel for the pros and cons. In aviation when you are told something, you always have to read it back just so that both parties understand they are on the same page. If I was to surmise the three days I have spent on your site I would read back the following:
1 - Wet sand if needed
2 - Remove wet sanding scratches with a rotary buffer
3 - Buff with an orbital and a blue coarse Rupes pad
4 - Wax, or strip and seal with a ceramic
Don't mess with success right!?
STEP 1 - Wet sand. I will be doing this by hand I think, as painful as this may be I just feel I can control the process and that the results with 2000 grit might not be as aggressive done by hand as they could be by machine (I MIGHT BE TOTALLY WRONG ON THAT)
Brilliant! Clear, easy, tangible! I hope this is the case everywhere across my boat, however I think I might drill a small and shallow test hole in the area near the gas filler cap, this area shows some darker patches though the gel which might be the resin below. I had to push the black levels in Photoshop to make it more visible however it is still hard to see in the picture. This is a 100% crop which also show some crazing in the same area. I have some factory gel so its easy to patch a small hole. That's a gel issue not a polishing question mind you!
Re wood sanders, YES THAT IS MY BOCSH! I guess I should not have judged free spinning polishers by my experience with a sander!
STEP 2 - The Rotary buffer. After reproaching a step that I hoped to avoid, I realize that my first attempt at this was using a Makita spinning a 10 inch pad hemorrhaging compound in all directions. I wonder if I would have had better luck using a smaller pad? What size wool pad do you start your beginners on? Would you use the Menzerna HC400 for this stage too?
Step 3 - Sounds like the course blue Rupes pad is proven, don't mess with it. Now I have to choose a buffing tool to spin it! I can purchase the Flex 3401 for $716, and the Makita PO500c for $389. This question really comes from my wife (and I don't wish to become divorced either), and she asked; "You don't do this every day Dan, do you really need the more expensive tool? Will the Makita get the job done?". Normally I wouldn't even question spending the extra money, but someone ate a bat and now the world has turned upside down and I have to make a business case for most of my current spending. Have you tried the Makita with the Rupes pad on any of your boat projects? Will it work or should I bite the bullet and get the FLEX even though I may have to sleep in my new boat for a couple of nights??
As far as compounds go, I can get the full range of the Menzerna grits, but I can also get the Rupes Zephir Coarse that you demonstrate in your post on the topic. In lieu of being able to get any Marine 31 products, could you recommend one over the other on gelcoat?
STEP 4 - Might leave that for another day, however is a forced rotation DA suitable for spreading wax and does one run the risk of dulling the Gelcoat with soft foam pads as was mentioned in other posts (albeit with a cutting compound, no mention of wax)?
My replay to Aaryn went away.. I think I closed the webpage before I hit send! DOH! I live in Auckland and he lives in Blenheim if his signature is correct. Unfortunately that is 475 miles and a 3 hour ferry crossing away from where I am! Great idea though, and it is amazing how we kiwis find each other on forums like this among thousands of users!
T
hank you for this amazing resource, and THANK YOU SO MUCH for the time you take to answer questions that must seem to get flogged I am sure!
I look forward to resuming flights to America and I hope you ship products to hotels as I will not forget this help when the time rolls around to do all this again!
Regards,
Dan
A couple of my replies are missing... Do they need approval or have I done something goofy? One was a quick reply, the other an advanced reply?
Don’t normally need approval mate , so not too sure. :dunno:
Repost??
2 - Remove oxidation/wet sanding scratches with a rotary buffer
Re wood sanders, YES THAT IS MY BOSCH! I guess I should not have judged free spinning polishers by my experience with a sander!
Thank you for this amazing resource, and THANK YOU SO MUCH for the time you take to answer questions that must seem to get flogged I am sure!
Regards,
Dan
Thanks Aaryn, lucky I saved a copy before posting it! My reply to you has gone (or I did something wrong more likely!). To answer your question, I am up in Auckland, eastern suburbs. As a BOP boy I didn't really think Auckland could ever be a place I would call home, but career dictated otherwise! I have to say though, I had underestimated the how good life could be just 45min out of the city! The Hauraki Gulf is an absolute jewel, hence the need for a larger waka (Maori word for canoe for those outside our colloquial bubble)! Blenheim is beautiful as well, love the South Island! I have family over on the other coast in Golden Bay... Don't visit as often as I would like :(
Nice. :props:
Yes Dan, I am down here in Blenheim & yeah Mike is right, I would be more than happy to let you get some hands on time with the Flex 3401 (Beast) - I have a bunch of tools in my shop from a range of Manufacturers but Flex is dominant partly because of how they’re built - these this are TOUGH & have that typical German build quality. Is it RA Johnstones that have the 3401 at $716NZ? If you can swing it for that without too much time spent sleeping in the boat ... that’d be my pick.
I do not however own the Makita PO-5000 but I have enough time with one in hand to know I don’t want one. Don’t get me wrong, it’s an okay tool just not for me.
As for your compounds, yes Menzerna & RUPES will hold their own with Marine 31, they all use fantastic abrasive technology & Mike will confirm this - that is key. Oh, & yes, absolutely you can lay down a wax or synthetic sealant with a gear driven polisher.
Rotary & wool pads - 7 inch is an average size & pretty manageable & RA Johnstone, Wyatts, Sorry, not 100% on UCC, umm - Cam at 3D, they’ll all have good wool pads suitable for Rotary use.
I’m honestly not the best guy to talk to in terms of boat detailing, I don’t tend to do enough to know my stuff. Mike Phillips on the other hand - find me somebody ... anybody who has even 0.1 percent of the content documented anywhere that Mike does on boat detailing/gel coat restoration.
If you need help with tools, pads, products etc I can’t promise anything but I can see if I can get you taken care of. :buffing:
O & hey - apologies for your work situation buddy ...
Yes, something in you post was flagged by the vBulletin software and the software "Moderated" the post.
I just found it in the Moderation Queue and approved it.
I'll take a look and see if I can find anything that would have caused this?
Yeperdoo - the tool sold so slowly that management made the decision that once the supply sold out Autogeek would no longer offer it.
This happens to any thing that doesn't sell well.
The key with this tool as my good friend Kirby established is making sure the pad is flat to the surface. This means holding the body of the tool in such away as to accomplish this.
With the longer tool chassis, (I love that term to describe the body of a tool), you and your grip plus arm muscles and even arm weight can have leverage over the face of the pad and how it presses against a body panel. If you have too much pressure on the forward handle the forward portion of the face of the pad will have leverage over the reciprocating components of the tool and cause pad stall.
If you have too much pressure on the rear grip, same thing only the the rear portion of the face of the pad will have leverage over the reciprocating components of the tool causing pad stall.
When you get a feel for how to hold the tool chassis to keep the pad flat to the surface as Dennis Gage would say,
It's a beautiful thing :)
And for those reading this into the future, here's the link to my in-depth review for the Griot's G9
Review: Griot's G9 - 9mm Orbit Stroke Random Orbital Polisher by Mike Phillips
And here's the first stand-out I shared for this tool after buffing out an old 2-door Chevy,
Mike Phillips said:
LOTS OF POWER!
This is the first tool I've used in my career where I didn't feel the need to go to the highest speed setting, which is 6 on the speed dial. It's that powerful, or better said, it's spins the pad so fast. I found myself running the tool on the 5 speed setting the majority of the time. Why is this important? Because I know my audience and they are looking for power. And in the context of a free spinning random orbital polisher power means the ability to maintain pad rotation under pressure.
This tool has TONS of power.
I used this tool in its factory configuration, that is with the factory installed 6" backing plate. I know most of you that have been reading my articles or have attended any of my classes know I show and recommend 5" backing plates for tools like this. Two reasons for this are,
1: With a 5" backing plate you can use 5.5" diameter buffing pads and simply put, smaller diameter pads tend to fit thinner body panels on modern cars better. That is you can buff out a section of a panel that has an edge on one side and a raised body line on the other side so you're never buffing on top of the edge or the body line. (good best practice)
2: Smaller, thin pads are easier for tools to maintain pad rotation. While this has been an issue historically, this isn't a problem with the new Griot's G9 - like I mentioned above, it has a TON of power.
RamAirV1
Actually - that's absolute apples to oranges comparison. Kind of like before RUPES introduced the Mille, people would ask
What's the difference between the RUPES BigFoot 15mm and 21mm compared to the FLEX 8mm BEAST.
There just in no real comparison as the drive styles of so different.
Here's the practical difference between the Makita PO5000C 5mm gear-driven orbital polisher (also the 5mm RUPES Mille), and the Griot's G9 9mm free spinning random orbital polisher.
With the free spinning tools - you can get pad stalling
With gear-driven tools - zero pad stalling
Free spinning random orbital polishers tend to be less aggressive and more easy to perfect SOFT paints with versus any gear-driven tool.
I discuss this as far back as 2012 in this iconic write-up for an old 2-door Italian job in post #32
Christmas Detail - Ferrari P4 - Move over Rudolf
What made you decide to finish out with the GV110 vs the Flex?
Pad size selection or the non forced rotation maybe?
Good question...
I find on softer paints like this car has that the PC style with a Fine Cut Polish finishes out nicer than with the more powerful Flex 3401.
The paint on this car was incredibly soft.
I only did my test spot using the Flex 3401 and end-results were acceptable, I did the 8mm free spinning step just to "make sure".
I also machine applied the wax using the Meguiar's G110 polisher.
And in context, when I wrote this in 2012 - The Makita PO5000C and the RUPES Mille had NOT been invented yet.
If I were to re-write one of the original sentences in what I wrote above it would read like this,
I find on softer paints like this car has that the PC style with a Fine Cut Polish finishes out nicer than with the more powerful GEAR-DRIVEN orbital polishers like the FLEX BEAST, the Makita PO5000C and the RUPES Mille.
Meaning, if I would have done the compounding step with any of the currently available gear-driven tools on the market TODAY - I would have still performed the polishing step with one of the free spinning tools on the market today because they tend to be less powerful, less aggressive and thus better at finishing out nicer on softer paints all other factors considered.
That's deep, hope it makes sense.
And for anyone that has never read the above write-up, here's some eye candy from it.
Perfect summary.
For some, they may opt to seal with a wax or sealant, personal preference.
Machine sanding with a sanding disc like the Mirka Abralon #2000 would be easier on you and leave a more uniform sanding mark pattern that would then be a lot easier to buff out.
No matter how good you are at hand sanding, you'll tend to leave TRACERS behind. Tracers are deeper, straight line scratches from either larger abrasive grains on the sandpaper or from any abrasive grain that becomes dislodged from the paper and then pushed over and against the surface inflicting a DEEPER random scratch as compared to the thousands of uniform scratches from the rest of the sheet of paper.
Trying to buff out tracers will drive you up the wall.
I use, and I show in my classes the Nikken brand of FINISHING papers, not SANDING papers as they use Unigrit Technology. Meguiar's use to have the marketing rights for these papers for all of North America but something happened? Now Griot's offers them under their brand.
Griots Garage BOSS Finishing Papers- Reduce Orange Peel - Review by Mike Phillips
I couldn't quickly and easily find a picture showing all the grit levels for Nikken in the Meguiar's brand but they do offer all grit levels. This picture is from when I taught a class in England.
Competition Ready Roadshow Detailing Class in London! - Products, Pads & Tools for the class!
Hand sanding techniques using Meguiar's Nikken Finishing Papers!
Hand sanding techniques are important skills you can use for a lifetime when the need arises like leveling orange peel and removing other surface texture issues in the paint. For this class I sent over a box that includes,
#2000
#2500
#3000
Meguiar's E7200 Sanding Backing Pads
watermark.php
watermark.php
Here's the full size version of your picture,
69342d1587609420-help-my-first-detail-project-its-26ft-boat-correction-8-jpg
And "yes" that looks like you're running out of the white gel-coat layer and hitting the darker normal polyester resin and glass behind the gel-coat.
The majority or wood sanders may "look" like a tool that could do what an orbital paint polisher will do but they simply will not rotate and oscillate a foam pad. They were designed to rotate and oscillate a THIN sanding disc.
Yes and yes.
Try to find a 6" or 7" pad. I really like the new RUPES wool pads. I showcased them in my last boat class. They were introduced at SEMA in 2019
Pictures: 2020 Boat Detailing Class - SOLD OUT!
The new RUPES Wool Cutting Pads - Nice pads! :xyxthumbs:
I have not tried the Makita PO5000C with the RUPES blue pads to remove holograms out of gel-coat. If I had more time, I have a chunk of boat in the garage and I could test.
My guess is it will work. It will be slower, but it should work. You'll want to put the pedal to the metal as the saying goes. Speed will be your friend.
Both Menzerna and RUPES make great abrasive technology and while I have not used RUPES a lot on gel-coat, my guess is it would work. I'm a HUGE fan of the Zephyr Gloss Compound. A lot of guys complain it's dusty. Me? I don't care about dust, duh... I'm going to wipe the surface no matter what.
I have used both compounds like compound/polishes and turned out flawless show car finishes in one-step on car paint. Now that's great abrasive technology.
You bet. I use the BEAST and the Supa BEAST and the CBEAST to machine apply everything. They also work great to machine sand gel-coat and aluminum. Too aggressive for thin paints thought.
Yeah, that's a journey all right. If you get stuck though, think of it as an adventure. Aaryn is a great resource, you would be glad you made the journey.
Regards,
Dan
No problemo Dan.
This forum is an extension of Autogeek's Customer Care. The difference between calling 1-800 phone number and posting your questions to this forum I - as you can see - I can share links, videos and pictures that you simply cannot do over a phone line.
Also - this conversation will endure forever for hundreds and even thousands to read and benefit from. You can't say that about a phone call or an e-mail.
