Help! Not able to remove sanding mark
Elliott.lwy
I was trying to wetsand some of the touch up paint down to OEM level. But I found a mark that is not able to remove (the darker circle) . Should I keep wetsanding until its gone or ...? Thanks in advance.
What grit were you using?
How many sanding strokes did you do?
What kind of pressure was used?
Were those marks there prior to sanding or did they appear as you were sand?
What are you using to try to remove the sanding marks?
I was using 2000 grit with medium pressure. And what is sanding stroke? It appears after I sanded it. And I am using me cuttin with fg400. Thanks :)
It kind of looks like you've sanded through the clear coat.
If you have sanded through the clear, if you keep sanding you're going to see the circle/oval continue to grow.
Stop right now and take some type of white colored polish and a white cloth and rub in the center of the circle/oval area. If you turn the cloth over and see the color of the basecoat... this is a bad sign...
If you just see the color of the polish I would still stop and buff the area with a compound and then inspect the results.
Factory paint is very thin, there's not a lot of room for error.
Crossing fingers now...
Ok well since you said this appeared while you were sanding I'm going to have to say you went through the clean coat while sanding.
Did you happen to see any color start to come up in the water or in the sand paper?
http://www.autogeekonline.net/forum...fing/21974-basic-hand-sanding-techniques.html
http://www.autogeekonline.net/forum/wet-sanding-cutting-buffing/22235-two-schools-thought-sanding-straightlines-crosshatch-pattern.html
Edit
As Mike said stop and check for any color transfer.
Yea you sanded through your clear.....why did you opt to use 2000 grit? Im sure 3000 or higher should have been done first...
Urgh...is there anything I can do to fix it?
A repaint of the panel would be you only fix at this point.
Here is an article about factory clear coats and freshly painted clear coats:
Wetsanding - Fresh Paint vs Factory Paint
Hand Sanding the Liberace Lavender Paint on the Titanic - This is a CUSTOM Paint Job
Machine Dampsanding the Joker Truck - This is a CUSTOM Paint Job
Ever since discussion forums starting popping up on the Internet there's always been a fair amount of interest in the topic of wet-sanding either on detailing forums or forums dedicated to a particular type of car, for example Corvettforum.com, a site dedicated to Corvettes.
And as with most topics there's a certain amount of confusion in general about the process, so here's just a tidbit on the topic of wet-sanding that I don't see addressed in a lot of threads on this topic.
Here's the skinny...
The majority of all wet-sanding is performed on fresh paint, there's no hard statistic but I usually float the percentage of 90% to 95% but admit that I could be off just because of the increased interest in the topic thanks to its popularity on the myriad of different discussion forums all over the world wide web.
Regardless of the exact percentage figure, the bigger picture is that the majority of wet-sanding is performed on fresh paint, not factory baked-on paint.
Here's why fresh paint is more often sanded
  • Fresh paint will tend to be softer.
  • Fresh paint will tend to be thicker.
  • Fresh paint will be sprayed on custom projects with more planning involved and higher expectations.
Here's why factory paint is more often not sanded
  • Factory paint will be harder.
  • Factory paint will be thinner.
  • There is little to zero discussion between the future owner and the technicians and or robots programed to spray paint.
Now lets look at each of these topic in a little more detail...
Fresh paint sprayed at a local body shop
Modern basecoat/clearcoat paints are catalyzed, that is they are chemically hardened, a simple analogy would be the way you mix a 2-part epoxy glue together and the resulting product hardens through a chemical reaction. If you've ever worked with fiberglass and polyester resin where a small amount of catalyst, (hardener), is added to the resin and the chemical reaction cause the resin to cure and harden, that's another simple analogy as to how catalyzed basecoat/clearcoat paints are hardened.
Contrast this to older style paints which were called solvent-evaporation paints in which the paints dried without the use of a catalyzing agent and instead simply dried and hardened over a longer period of time as the solvents mixed into the paint evaporated.
Even though most modern paints are chemically cured, there is still a window of time where these paint are not 100% hardened and during this window-of-time the paint is what is sometimes refereed to as still wet, not like in wet gooey paint but as in still soft enough to easily sand and buff.
There are also what are called fast drying, medium drying and slow drying reducers which are solvents for mixing in with the paint to give it a thinner viscosity before spraying. A painter can match their choice of reducer to speed up or slow down the drying time.
All these factors can affect paint hardness or softness in the first few days that follow after the car leaves the paint booth.
Usually, if the painters knows the car is to be wet-sanded after painting he can adjust how he mixes the paint to give the person usually called "The Painter's Helper" time to sand and buff the paint before it becomes too hard. Time of year which includes temperature and humidity can also play huge factors in drying or curing time and can be factored in and adjusted for.
Now here's what's key about this, sanding paint is always easy whether the paint is fresh or baked-on at the factory, in simple terms, (very simple terms for the purpose of explanation), sanding paint is putting scratches into the paint.
Again... sanding paint is easy, it's the part where you try to remove your sanding marks that can be difficult. The harder the paint the more difficult it will be to buff out your sanding marks. The softer the paint the easier it will be to remove your sanding marks.
At the body shop level, again if the painter knows the car is to be sanded and buffed, they'll usually add an extra coat or more of paint, this gives the painter's helper a little more wiggle room to sand and buff and not worry about sanding or buffing through the clear coat and exposing the basecoat.
I've also met painters that will just spray a thicker or heavier coat and only spray 2 coats of paint but through factors they can control they can spray it on thicker and therefore not have to spray a third or fourth coat.
Fresh paint will be sprayed on custom projects with more planning and higher expectations.
If you're having a custom car project painted, for example you spent months and more than likely years rebuilding a classic Mustang and now it's time to get it painted, in most cases you'll be meeting with the painter ahead of time planning out the paint job and it's at this time you discuss with them your expectations. If you want the car sanded flat and then buffed to a high gloss for a true show car finish, (if this is you goal or expectation), then the painter will spray an extra coat or two of paint to provide plenty of film-build for the painter's helper to safely sand the paint flat. They will also build in the cost of the extra materials, (clear paint), time and labor to your bill.
Summery
Fresh paint sprayed at your local body shop, specifically the clear layer, will tend to be thicker than the clear layer that comes from the factory and it will tend to be softer and easier to sand and buff shortly after the car comes out of the paint booth. Because it's thicker there is a little more safety margin or wiggle-room for the person to sand and buff the paint and not break-through the clear layer and expose the basecoat. Because the paint is fresh it's going to be softer than factory baked-on paint, at least for a window of time and this will make buffing out the sanding marks faster and easier.
Factory baked-on paint
The original paint sprayed onto your car as it traveled down the assembly line at the manufacturer's plant is in most cases baked-on at high temperatures before any wiring or the interior is installed and for this reason higher temperatures can be used since there's nothing to melt of catch on fire in or on the car yet. By the time the car pops-out the end of the assembly line the paint is fully cured and hardened. For this reason it will still be easy to sand, (that's putting scratches into the paint), but it will be more difficult to remove your sanding marks out of the paint.
At the factory, the paining process is very automated and the amount of clear paint applied to the vehicle is done so in a tightly controlled manner and to very stringent specifications. You don't have the ability to ask for an extra coat of clear, or for a thicker coat of paint to be sprayed and from a materials cost point of view, it's probably safe to say that the amount of paint used to coat each car trends towards being the minimum amount, not a generous amount. Simply put, factory clear coat paints tend to be very thin compared to what you can get at your local body shop.
Summary
Factory paint will tend to be hard and thin, it will be easy to sand but more difficult to remove your sanding marks out 100%
Factory paint will be thin and if you're not really careful you'll break-through the clear layer and expose the basecoat or color coat either during the sanding process or the ensuing buffing process as both procedures remove a little paint.
The above is usually the portion that's left out of most threads on this this topic as it's discussed around the web on the various discussion forums. My theory is because it's left out of so many discussions on the topic, a lot of people don't understand the above differences in types of paint, (fresh vs factory), and that's why you'll often see someone posting that they're interested in sanding the orange peel on their factory finish till its' removed, (till the surface is flat), and then trying to remove their sanding marks, often times with a PC style polisher.
That's just my theory... but I've participated in a lot of these types of threads and when point about the differences listed above it's usually an eye-opener for those thinking about sanding their car's factory hard and thin paint.
Looks like it was a combination of grit the pressure used, and maybe even the technique. I know it's too late now, but for future reference, denim pads on a DA work great for leveling out touch-up paint, and are a "safer" choice than sanding. Yes, you can still go through your clear, but it takes more time as the pad will likely glaze over and stop cutting first - or your product will be spent. At least that's been my experience...
Borrow a paint guage maybe from an autobody shop and take some measurements. Looks like a pretty big area you sanded to correct touchup paint. Assuming you did not go through the clear you may want to buff out the sanding marks with a rotary or follow up the 2000 with 3000 and use a DA with mf pads to remove the sanding marks and inspect the end result.
If you went through the clear the best fix is a respray.
If you are looking for a DIY fix. You can always try respraying clear yourself. I'm guessing this panel is your hood. If so it's easy to remove so you don't have to tape off the car. Get 3-4 cans of 2K clear, degreaser, tack cloths and respray the panel. It's not like you're going to loose that much. Remember to wear a mask when spraying 2K clear.
Update: I think I have sanded through the clear. But it doesn't look that bad after compound (FG400), polish (SF4000) and one coat of sealant (M21).
Thanks for the comments and suggestions. They are really helpful. :)
Actually, judging by that picture, you may not have gone through your clear... Base coat has no gloss to it whatsoever.
Looks ok. You can see the outline but overall it's not too bad.
This is why is always important to use a paint thickness gauge before you start sanding.
Did you ever do the simple test I shared in post #4 which will tell you 100% if you did or not?
Either way, it did polish out nice. At this point, the best thing you can do is keep the aread sealed and protected. So keep an eye on it and wax often.
I know. I always want one but I would invest in a rotary buffer first. :p
Yes, I have done the test and found the color of basecoat on the cloth. Anyways, learn by doing :buffing: It was a great experience. Fortunately it turned not that bad.
Yes, I have done the test and found the color of basecoat on the cloth. Anyways, learn by doing :buffing: It was a great experience. UNFortunately it turned not that bad.
^fixed :)
Also, PTGs can be picked up for cheap. It is hardly an excuse not to have one. If you plan on doing any sanding, it is much cheaper to buy a basic PTG than it is to repaint a panel.
http://www.autogeekonline.net/forum...aint-thickness-gauge-affordable-everyone.html
I have this particular PTG and can say that it works very well!
