Hey all! Newbie to Auto Geek! I've been experiencing a few issues with my detailing setup, maybe some of you guys with experience can help out!
I've got a 275 gallon tote that I usually only fill up a quarter to half way, connected to a Shurflo 1.8gpm on demand pump powered by a 12v rechargeable battery with on/off switch, routed to Griotts portable water deionizer, fed into my AR Blue Clean 630 TSS. The Blue Clean is powered by an EU3000is generator and that's my first issue truthfully. I've connected the pressure washer via the 23.3 amp connection on the generator with a 30amp to 15amp ac adapter, and extension cable. However, whenever the pressure washer is engaged, the overload alarm light turns on, the pressure washer ramps up to max flow, and then slowly loses pressure. The eu3000is overload alarm light turns off while still engaging the pressure washer, but the pressure washer flow decreases and performs less than stellar.
The AR Blue Clean 630 TSS is rated at 2.2GPM, so already looking at upgrading the Shurflo pump to something with higher GPM. I'm guessing that would help the pressure issue quite a bit, as the 630 TSS gets a bit louder with grinding gear sounds and lowers pressure with continuous usage on the 1.8GMP demand pump.
Any way to increase this setup's performance? Is the eu3000is limiting the rate of flow for gpm? Maybe it's just the shurflo pump? Newbie definitely struggling with this setup for optimal results. The eu3000is holds its own with all other equipment including my MasterBlaster. Feedback definitely appreciated!
Edit: BTW the AR Blue Clean hooked up to direct power through my garage performs a bit better with better overall flow rates and pressure, but still causes grinding noise from the pressure washer and requires me to let off the pressure washer gun and re-engage to bring back the higher flow rate. Whenever I let up on the pressure washer trigger, I can hear the pump engaging for 5-10 seconds before it turns off and then re-engaging the pressure washer trigger is back to better overall pressure. It's a continuous loop though and leads me to believe the pump isn't operating at optimal conditions with less GPM than is necessary for the AR Blue Clean.
