Hello, my brother tried removing a scratch from his car with 400 grit sandpaper. I tried removing the marks by wet sanding with 800 then 1500. I then used my PC with CG V34, 36, then 38. It looks a lot better but it's still clearly there. I used the above primarily because that's what I had available at the time (I'm willing pick whatever I need up). Can anyone suggest a method of removing these marks? I normally would just try a bunch of stuff and see what works but I'm weary of sanding too much off if I don't need too. The car is a 2013 Audi A5 and it's dark blue.
I appreciate any help I can get.
