sayroger
- Nov 17, 2013
- 316
I worked on a 1999 van toady. It had the decals removed but the adhesive was still on the van. I tried several different products paint thinner, rubbing alcohol, WD40, M105 with orange pad on flex. None worked very well. I ended up using alcohol one a scrub sponge marred up up the finish pretty good looked like i wet sanded it. Luckily i only had to do one side of the van the customer had the other side finished.
Any suggestions for the next would help a lot Thanks
