This product should not be used on clear coat paint systems. The formula was made for single stage paint. Its trash's clear coat. You will need to follow up with quality clear coat safe products.
Nextime use Meguiars.
Go to the store and pick up a bottle of Ultimate Compound and a microfiber applicator and apply the product per the instructions using firm pressure the entire time while applying until the compound starts to go clear or dry up. This product works wonders by hand and will absolutely clear up your paint.
All Meguiars current over the counter products are clearcoat safe.
If you a big fan of the paste style rubbing compound, Meguiars makes one of those as well. But they responsibly made it clearcoat safe considering the average guy trusts the products on the market currently to work on there cars they purchase currently as well. It only makes sense.
Turtle wax should be ashamed and should either pull this product off the market or make it clearcoat safe. Even if you follow there full instructions and matching polishing compound product, it still looks like hell on clearcoat paint. Even with decent technique.
Like Mike Phillips has said, in the old days they used to replace scratch's with products that caused there own scratches. Then they would cover that up with a wax and call it a good job.
Turtle wax rubbing compound is one of those products that is ancient.
aside from my rant,
the best and fastest solution to your problem is a trip to the store, along with 10 dollars to buy a bottle of this,
Meguiars Ultimate Compound, polishing compound, rubbing compound, meguiars rubbing compound, meguires, meguiars polish, auto compound polish
