Help, shopping list?
kjk66ss
Hey everyone. I just got a new-to-me chevy diesel truck, in grey stone metallic. I am placing 2 orders the first one is already being shipped and contains;
Pinnacle car shampoo
Assortment of cobra microfiber towels.
Pinnacle spray souveran wax.
List 2 is what I'm working on now.
Wolfgang deep gloss paint sealant 3.0.
Griots garage window/glass cleaner.
Pinnacle clay bar with spray lube.
Now I want to know, will the pinnacle spray wax work and be compatible to use with the Wolfgang paint sealant for the in between wax jobs after washing?
Does list 2 in general look decent and good to use in lieu of list 1?
Next I started looking into doing a polish but am wondering if my rotary buffer that I got from harbor freight will work to do a polish job. And what product is good for polishing?
I will mention I am new to all this. Last time I tried using a cutting compound on an older truck, I was too afraid to burn the paint and probably would have done a better job using my hand then the buffer.
You still need:
2 buckets
Grit Guards
Good wash sponge
Leaf Blower at a minimum or Metro air dryer (the less you touch the paint the better)
Clay
Some sort of clay lube
Unless you have experience with a rotary stay away from it on your truck (practice on a friend's vehicle :-) )
Do some research here and you will find all of the answers that you need grasshopper. The How-to section is very informative. Be careful, this is addictive and expensive. Don't ask how I know.
APC (All Purpose Cleaner)
A wheel brush
Nanoskin Autoscrub Sponge (clay alternative)
Also agree with the two buckets and grit guards
If you have no experience with a rotary then stay away. Lots of damage can be done with a rotary. Maybe a DA (dual action) polisher. U can also look into so all in one products for removing swirls and scratches like Meguiars D151 or Menzerna PF2500. These are going to provide a good cut that finishes down well like a polish and provide a minimal wax protection but you have the Sealant for that.
thanks for the replies. i forgot to mention that i have buckets from lowes and a wash mit with my first order. i do not have any swirl marks yet... but once i do the clay work with the pinnacle clay im going to order i just want to be sure to eliminate and small marring i pick up from the clay.
here is a picture of my truck so you guys can get an idea of the color and the finish on the wheels
thoryamaha: wont i need a rotary or DA buffer to use the Meguiars D151 or Menzerna PF2500 that you listed?
I'm not trying to sound like a ####, but its apparent you've been reading too much into things online --- its great you've done some homework but you're in the over thinking stage
Plus I'm sure you have swirls, everyone has swirls, its just varying in degree and ideally you instill them at a very low and minor rate using proper techniques etc
if you want a spray wax to use in between waxing then pickup cg v7 or eco touch spray wax they're both great go far and extremely slick
You're absolutly right,lol.and you dont ssound like a ****, i have been lost on this forum reading and browsing the store that im starting to think i need one of everything.
i guess i should have worded my statement a little better. it doesnt have swirl marks that bother me yet. and depending on the light i can see them at all at 2-3 feet away.
starting this thread has me more confused. haha. im trying to keep the budget realitivly low and just get the basics to do;
1. wash
2. dry.
3. clay.
4. sealant instead of wax because i like in southern california and take the truck camping out in the desert alot and "read" that the sealant protects better. if the CG v7 is better combined with the wolfgang sealant then i will not use the pinnacle spray souveran.
chemical guys wash and gloss
http://www.autogeekonline.net/forum...nopsis-2-chemical-guys-citrus-wash-gloss.html
a quality drying towel or two // or a leaf blower blow vac etc
mothers clay bar kit or megs professional mild (blue) clay
petes 53
http://www.autogeekonline.net/forum...-polymer-white-carnauba-paste-wax-review.html
petes is a great value, great looks, boasts stout durability -- it is a hybrid wax -- just keep it away from your trim if you have any I don't really see much of any in the picture
I agree with SON1C with the chemical guys v07. I have never used it personally but it would be great for what you want.
I also agree with the citrus wash and gloss. It's great stuff. I traded for some with a fellow member and I like it a lot.
if i use the CG citrus wash + gloss, i will need to wax after every wash?
no its wax safe unless you use the wax stripping ratio
1 cap vs 16 caps basically
petes 53
thanks SON1C. now i must say that i had placed an order a few days ago and is it worth it to return;
Pinnacle car shampoo/ CG citrus wash +gloss
Pinnacle spray wax / CG V7.
the ones in the red is what i already have ordered few days ago.
i will order the petes 53 instead of the wolfgang deep gloss 3.0
The citrus wash and gloss gallon costs as much as a 16oz of pinnacle. You can also get a gallon of v7 or even Megs xpress spray wax for a few dollars more than the pinnacle spray and they work very well.
i added the chemical guys "forum favorite", comes with the foam applicators,microfiber ,pete's 53, V7 spray, and the black light radiant hybrid finish. says the radiant finish will blend very small and light swirls.?
I haven't used black light personally but from what I've read it's a polish glaze sealant type thing. No one really knows lol. It should fill in light swirls and stuff but definitely top it with the Pete's or
V7 to get some protection.
thanks. yeah those three are part of the package. i planed on using that black light stuff after using the clay bar and before the wax. it says the black light can be applied by hand or machine.?
That sounds about right. Are you using a machine?
For most things they can be applied by hand or machine just depends on what you are going to use. Can't wait to hear how Black Light works for you.
