Help. Stream Cleaner or Extractor
Coastalf350
Hi, I own a Yacht Management business here in south Texas. Im looking at getting a steam cleaner or extractor to do boat carpet interiors. Keep in mind I work on sport fishers ranging from 31 feet to over 60 feet long. Any help in the right direction will be greatly appreciated.
I would opt for the steamer,there are so many uses for that on a boat.If you have a large yacht to do as far as carpet just rent one for the day.
Good point. I hear alot about the VX5000. If I do decide on a steamer I would want one big enough to do the diesel engines on these boats.
The VX5000 is nowhere near big enough for that kind of job. I have one and consider it a fairly light duty tool.
Steamers are mostly for topical cleaning i.e. cleaning the surface.
Extractors deep clean. That is simply put, they inject hot water into a material and then immediately extract it via vacuum.
If you need to deep clean fabric seats then the extractor would be the way to go. If you need to topically clean the surface of vinyl seats then the steamer would be the way to go. If you need to do both then you need both tools.
I've never used the VX5000 so off hand or without doing a Google search I don't know if it's a continuous fill type or not. I use and teach how to use the Dupray line of steam cleaners and not only are they top shelf quality, they are also continuous fill and you can use tap water not just distilled water and they have the best attachments that I've ever seen.
Most steam cleaner lack the continuous fill capability and their attachments are lacking. Not the Dupray models.
Half of the forum work I do is simply reemmbering articles I've already taken pictures for and written.
For example...
Here's what a Dupray Steam Cleaner can do!
At our September Detailing Boot Camp Class we had an all original 1967 Lincoln Continental in our class for a full interior and exterior detail.
Here's how the original white leather interior looked BEFORE my class took the Dupray Hill Injection Steam Cleaner to it...
watermark.php
watermark.php
watermark.php
watermark.php
watermark.php
If you look closely at the area below the pull handle you can see a small area that I cleaned to show how much room there is for improvement...
watermark.php
Not pretty...
Here's the after shot...
watermark.php
And the original single stage paint was resurrected using the Rupes paint polishing system.
Rupes Bigfoot Polishers Detailing Class & Extreme Paint Restoration
watermark.php
The Dupray Steam Machines are really well built, well thought out and capable of amazing results.
See my two article here for more information...
How To Use the Dupray Hill Injection Steam Cleaner
Steam Cleaning a Ferrari Interior with the Dupray Hill Injection Steam Cleaner
On Autogeek.net
The Dupray Hill Injection Steam Cleaner
The Dupray Tosca and the Dupray ONE Plus both would be great steamers too and the both offer the continuous refill feature.
Dupray Steamers
Here's another article I've written for the Dupray Steam Machines
This is an amazing steam cleaner. I've only used it a few times since Autogeek brought them into the store but I'm so impressed with it's design, function and ease of use that you'll see a lot more steam cleaning projects coming up in the future.
First, lets take a look at what comes in the box....
The Hill Injection model comes fully self-contained in it's own storage case.
watermark.php
Here's all the various accessories that come with the Dupray Hill Injection model.
watermark.php
Here's a few screenshots from the Dupray website
watermark.php
watermark.php
watermark.php
watermark.php
watermark.php
watermark.php
Continued...
Now let's take a look at how to get your new Dupray Hill Injection Steam Cleaner up and running....
How to turn the unit on
The main power button is in the back behind a protective, flexible cover.
watermark.php
Press the rocker switch to the on position and the power indicator light will light up.
watermark.php
You can tell power is now supplied to the unit as the digital display will light up.
watermark.php
watermark.php
Next press the power button to the ON position to supply power to the heating elements.
watermark.php
watermark.php
Next turn the heating elements on....
watermark.php
watermark.php
When the steam indicator lights comes on at 330 degrees you're ready to start using steam to clean...
watermark.php
watermark.php
Continued...
For cleaning car interior, you're going to love the triangle brush with the spring loaded towel clamp. This makes placing a clean towel onto the brush fast and easy and it holds it very securely.
watermark.php
The size of the brush head is PERFECT for any standard size 16" square microfiber or cotton towel.
watermark.php
Simply fold the towel diagonally to create a triangle shape like this...
watermark.php
Place the brush head onto the folded towel like this with a little more extra space at the top. (not much just a little, you need some excess at the back also)
watermark.php
Use your finger or thumb to depress the spring loaded clamp....
watermark.php
Then simply pull the three corners of the towel up and through the open slots of the clamp....
watermark.php
Should look like this when done correctly...
watermark.php
watermark.php
You're ready to start cleaning and disinfecting without using chemicals.... this can be a real lifesaver if you're allergic to or sensitive to cleaning chemicals.
watermark.php
Click the below link to see the rest of the pictures showing this tool.
