Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Help - water spots returned even AFTER machine polishing?
Anytime I get questions via e-mail, a PM or a FB message I prefer to invest my typing time where
A: It's easier for me to share links, pictures and videos.
B: More people can read and thus benefit from the information. (no just one set of eyeballs)
The reality is, most people that contact me found me via an article I've written or a reply I've written on this forum. The thing is, instead of figuring out that the whole reason they are contacting me is because they found me via an article or answer I wrote on the forum that they to should bring their question to the forum because not only will that help them.... but it will help a future "them". If I answer everything in a private e-mail or other touch point, no one would find and contact me. It's a cycle or pattern that repeats as long as everything is shared in the public domain.
The above is kind of wordy but re-read it slowly and it will make sense.
So I get an e-mail asking,
Hello Mike,
watch you all the time on various TV shows and am convinced you are the "go-to guy" as far an auto finishes.
short story - black single stage paint fiberglass car had been done with wolfgang (clayed, compounded with menzerma, wolfgang swirl remover, wolfgang polish, wolfgang sealer, porter cable & lake county pads about 2 years ago (always garaged & usually also covered). Was showing some minor holograms from washing and spray wax or detailer, however still looked good, when first done was awesome and drew comments about. (please also note have same situation with black lexus coupe & dark green tundra truck both of which were done similarly)
working in garage, cutting mdf, got sawdust all over car. no big deal right ? had to park outside, and of course it snowed on the car, while sawdust still there. weather here in Denver area, unlike Fla, was extreme cold, snow etc daily so sat on car for quite a while.
when washed car had what looked like water spots all over. tried all i know for solvents etc to remove, no good. finally tried menzerna compound and seemed to remove, although took a lot of effort. so... bit the bullet, clayed, compounded, wolfgang swirl remover, wolfgang polish, wolfgang sealer using porter-cable, whole car. although took probably 15hr plus, looked great, seemed that were all gone, looked as good as did first time done.
drove car first time yesterday, hot, sunny. when returned home and put in garage ... all the spots (which were gone previously) were back.
again tried various solvents, (strongest being lacquer thinner .. cringe !!!) on small portion, nothing seems to improve till compound (test section by hand) however did this previously by machine (porter-cable) and appeared to work, but sadly did not. really don't want to redo, only to find did not work again.
am hesitant to try rotary buffer as too easy to burn.
PLEASE HELP seems like I did nothing to improve.
THANK YOU for your time and consideration.
E.A.
Great questions E.A.
Thank you for your patience for me to return to work to reply to you. Happy to hear you found me via TV and I've worked on lot in the TV world as it relates to sharing proper techniques for car detailing, but the majority of my work can be found on this forum via my,
Typing time is limited. So I try my hardest to answer questions on the forum where I can format text and share pictures and videos plus "links" to more info. With e-mail - it cannot be counted on to display all these things correctly PLUS only one set of eyeballs ever sees the info.
Hang tight, I'll do my best to answer your questions.
Hello Mike,
E.A.
- How to articles
- Replies to questions from forum members and people like you the send me your questions via e-mail.
