Hi all,
I have a aluminum tonneau cover (Bakflip) that is a sandwiched design (some poly inside) with an aluminum top and bottom side. The aluminum is "textured" and the top is getting oxidized and "greyish".
I've hand worked a small section with polish which helps greatly; but I'm a little old and grumpy to do the entire top by hand
; but am also concerned with using a DA as I'm concerned I will work off the paint/color without getting down into the grooves as needed.
Hoping these pictures come through so you can see the texture a bit. Any ideas / help for polishing or other ideas would be appreciated!
Thanks,
Rick
Thanks,
Rick
