BMack
- May 27, 2017
- 47
First time posting although I'm a long time reader and learner.
I'm going crazy trying to final polish black paint on a 2016 Dodge Challenger. Everything is fine up to this step. Two bucket wash, microfiber towel & blow dry, clay bar, 5" microfiber cutting pad with Meguiar's Ultimate Compound. Compounding leaves behind a swirl and scratch free finish with micro marks from DA cut. Then when I go for the final polish I get these faint larger circle type marks. They can only be seen when I hold the light at certain angles and do not look like the DA marks left after compound. They don't even look like scratches, more surface marring of some type. As I move the light they appear holographic/rainbow. The paint looks perfect when I hold the light a different way.
I'm using a TorqX DA and have tried various combinations of Gyeon Polish, Chem Guys V-38 and Meguiar's Ultimate Polish. I've tried foam and microfiber finishing pads. I've used speeds 3 to 6 and used proper technique according to all the info read and videos watched. Surface is clean, new microfiber towel, new pads, etc. Pads are primed with product with 3 dime size drops afterwards. Product is spread around on speed 1. I've also tried lighter and heavier foam pads with the polish. I've wiped down the area with 50/50 iso and Gyeon Prep.
Is this normal? Should the paint be perfect (as is possible) without these lines? Maybe I'm over thinking it. Maybe I need to up to a better DA polisher if the Torq is junk?
Here's the before and after. Appreciate any suggestions. Could come down to the operator, but I feel I'm doing everything correctly.
