....I'm in the process now of using the Ceriglass kit with the 5" LC glass pads on a PC 7424 on my windshield. So far, bad luck. I can't give it a good review. I bought the kit to get fine scratches out of my windshield from where the previous owner ran dirty or dry wiper blades. Instead of doing that, it put in fine tick marks/micro marring into the windshield glass. First off, using this polish with a DA polisher makes a complete mess! Imagine mixing 8 ounces of white paint with 8 ounces
of White-Out : thats the consistency of Ceriglass. Secondly, the polish has almost zero work time with a DA. Your lucky if you can make 2 passes before it dries to something that resembles dried White-Out. The very short work time could be causing my micro marring, I'm not sure. As the glass polishing pads are thin as cardboard and hold no product. I even tried a hydro tech pad with no better results. Let me say, the micro marring is very faint, you can only see it when looking close with a Brinkmann Xenon. Looking through the glass, all looks fine and clear, but this micro marring can't be normal. I even tried extending the buffing time with a spray of distilled water, didn't help. I think I heard Car Pro, the people that make CeriGlass, recommend using some type of special wool pad with the product, not the wafer thin glass polishing pads LC makes. I wish I knew that before I started. Maybe I got the wrong pads, but the kit doesn't tell you that and does say you can use a DA (doesn't say anything about rotary). However, all is not lost. I found the glass polishing special hand foam pads that do come with the kit work much better, make less mess, and have a slightly increased work time. The bad is, it's now going to take me FOREVER to repolish my windshield by hand - and; I'm probably going to have to order another kit to finish it. As, towards the end of working with the DA, I was using a ton of product just to try to keep the product somewhat wet. When I was working with the DA, everything stayed cool to the touch, the glass or pads never even got warm. The is a finicky product at best, I can't see how anyone could remove scratches with Ceriglass, a DA, and LC glass polishing pads. Maybe I am too picky, as the micro marring is very slight, but was definitely caused by the Ceriglass and the glass pads. It does remove water spots, but I would only recommend using this product by hand unless you know something I don't. Also, I find most type I water spots are easily removed with a finishing regular paint polish (or an AIO) like Menzerna Final Polish II or Poor Boys polish and sealant. So, today I'll be developing Popeye arms polishing my windshield over by hand. Anyone else use Ceriglass with a DA then closely inspect the glass with a light like a Brinkmann???
***Also, if your going use this with a DA, make sure you have a ton of towels around to clean the polish off the glass after buffing. As, once a towel gets the product on it, it seems to just smear around any additional product, forcing you to keep switching to a new towel. I must have used 20 microfibers just to do my sunroof and windshield. However, when working by hand it's a lot easier to remove the Ceriglass and a lot more manageable. Before using the product, I cleaned and clayed the glass, then wiped it with IPA.
