Hello Autogeek community! I'm having some issues using Meguiars D300, perhaps you could shed some light on the situation...
Car: 2007 BMW 335i Sedan - Monaco blue metallic
Polisher: PC7424 with LC 5" backing plate
Pads: Meguiars MF cutting pads
I spent yesterday cleaning and prepping my car for the winter months, after a much neglected spring and summer. My intent was to use HD Speed on a Meguiars thin foam finishing disk (which worked wonderfully!) except in the rougher areas which I planned on using D300 on the MF cutting pad. However, when I went to test out that combination, it was quite difficult to wipe off the D300. I had to use ONR in a spray bottle to loosen it up to wipe clean. I tried to follow combinations with similar results:
primed the pad and went to work at speed 5 for 4 overlapping passes, tried again at speed 6. This was repeated trying 6 passes in case I wasn't working in the D300 enough. Same results
didnt prime the pad, used 5 pea sized drops, and worked in a similar pattern described above. Similar results.
For fun, I tried using a LC flat orange pad primed, and worked at speed 5 with 4 passes and it worked great! It wiped off easily and had enough correction for my desired finish.
I played close lose attention to arm speed and downward pressure, never stalled the polisher, etc. I'm certain it has to do with how I'm using the product, and not the product itself. Could anyone provide some insight to my issue?
Thanks!
Thanks!
