Worked on a 99 GMC Conversion Van today.....the dash has some fake wood grain trim.....I wiped this trim down with water only and at the end of the day....there are spots on the trim that are cloudy! Looks Bad....
hOW CAN i FIX THIS?Feed back please
How much water? If it got behind the molding, its probably fogging there now. Can you try to wipe away with a proper interior trim product? If you don;t have that do you have diluted APC to interior trim strength ? If you don;t have that can you mix up some Dawn and hot water and wipe away with a MF (don't soak the MF, just dab a corner in the solution).
