I clean first with plastic cleaner like Meguiar’s or PlastX.
Then I tape around the lens.
I wet sand to remove the old coating. I start with 500 grit because these are really rough. I use 1000, 2000, 3000 and 4000 grit sandpaper hook and loop on a buffer.
After all the coating is removed (when you see the slurry is clear), I polish with an orange pad and compound followed by a white pad and polish. I clean the polish off with Chemical Guys WipeOut. Then I finish with 2 coats of Meguiar’s Headlight Coating
Acura Headlight Restoration - YouTube
About 1 hour of time, less than $5 of product, $100 cha ching.
