Congratulations on purchasing one of the finest dual action polishers on the market. Mike Phillips has done a tremendous job writing articles about these polishers and polishing in general and I've posted just a few of them for your reading pleasure.
Car Buffers & Polishers
Dual Action Polishers
How to choose the right polisher for your detailing project
DA Polisher Trouble Shooting Guide
How to prime a foam pad when using a DA Polisher
How much product do I use with my DA Polisher?
Wet Buffing Technique
DA Polisher Articles - Help for Newbies to Machine Polishing
A little on choosing the right foam pad.
Personally, I prefer using 5 1/2" foam pads on all my machines. In my opinion, the smaller pad is a perfect balance between size and efficiency. Smaller pads make controlling the polisher easier putting less stress on the machine and the user
Foam Pads
Yellow Cutting Foam - Use this pad to apply compounds or polishes to remove severe oxidation, swirls, and scratches. It is the most aggressive and should only be used on oxidized and older finishes. Always follow this pad with an orange or white pad and a fine polish to refine the paint until it is smooth.
Orange Light Cutting Foam - Firm, high density foam for scratch and defect removal. Use this pad with polishes and swirl removers. It’s an all-around pad that will work on most light to moderate imperfections.
White Polishing Foam - Less dense foam formula for the application of waxes, micro-fine polishes and sealants. This pad has very light cutting power so it’s perfect for pre-wax cleaners.
Gray Finishing Foam Pad - Composition is firm enough to withstand added pressure during final finishing to remove buffer swirls. It has no cut and will apply thin, even coats of waxes, sealants, and glazes.
Blue Finessing Foam – Pad has soft composition for applying glaze, finishing polish, sealants, and liquid waxes. Flat pad provides full contact with paint surface to minimize the pressure applied by the user.[FONT="]
[/FONT]
