Hi AG's Advice on Prep For Detail?
Brucet
Hi
I'm fixin' to do a spring detail. I detailed in the fall and finished with Klass sealant glaze which still seems fine. I want to do a better swirl removal and wondered if I should remove the SG first and if so what to use.
Thanks
Bruce
The SG will be removed when you polish. No need to remove it beforehand.
Brucet said:
Hi
Thanks
Bruce
I'd go ahead and polish. It will remove your SG, but that's fine. It's as durable after being on your finish for so long. Just start over and detail, and post some pics when done.
WASH ---- CLAY --- POLISH ---- PROTECT
the polishing step with remove SG as abrasive, and will help remove the swirls.
