Ho often to apply polish for daily drivers
depends on what you mean with polish? if it's just with a final polish to to reduce marring and roadfilm, you can do it every year, but not to aggressive, clearcote ian't growing back
Unless you're driving the car through the tunnel washes all the time, I can't see why you would do it more than once a year.
Right now, I polish in the spring to correct any damage done over the winter and then just wax (maybe glaze) in the fall. I only do a major detail twice a year.
So do you use a glaze every wash in the fall then Ive been kind of curious about black hole.
Not every wash...only once for the season. The glaze goes under the sealant or wax.
This year, I got a black car just as the fall weather started to get cold. Instead of correcting the dealer swirls, I hit the car with a coat of Black Hole to fill in and hide the swirls, and then layed my winter protection over the top of it. The results were really good; enough so that I'll probably use it as my fall/winter prep routine going forward.
Polish in AG world means and something with cut
Polish in normal world means wax.
Are you talking about a polish ie wax? Or polish as in cut swirls?
Good point!
Polish, a little touch up 1 or 2 times a year assuming you have good washing technique.
Wax/Sealant, 2 or 3 times a year depending on a wide range of conditions :)
I would say once a year.
That's taking into count maintaining between waxing with a Quick Detailer and Spray wax.
I think he meant Polish. Not polish.
1) The bandage was wound around the wound.
2) The farm was used to produce produce.
3) The dump was so full that it had to refuse more refuse.
4) We must polish the Polish furniture.
5) He could lead if he would get the lead out.
6) The soldier decided to desert his dessert in the desert..
7) Since there is no time like the present, he thought it was time to present the present.
8) A bass was painted on the head of the bass drum.
9) When shot at, the dove dove into the bushes.
10) I did not object to the object.
11) The insurance was invalid for the invalid.
12) There was a row among the oarsmen about how to row.
13) They were too close to the door to close it.
14) The buck does funny things when the does are present.
15) A seamstress and a sewer fell down into a sewer line.
16) To help with planting, the farmer taught his sow to sow.
17) The wind was too strong to wind the sail.
18) Upon seeing the tear in the painting I shed a tear..
19) I had to subject the subject to a series of tests.
20) How can I intimate this to my most intimate friend?
Maybe he did mean polish.
I think you would be better off deciding on when to polish out your car based on the condition of the paint over just doing things based on some arbitrary detailing schedule.
AIO- A all in one type product to me is something that has cleaners and abrasives in it. I might use the type of product 2to3 times a year on average.
Finishing Polish- for example M205 I will use the type of product as often as needed to correct isolated defects. I will polish out my truck on average every year to year and half. But where I live I don't have to deal with winter conditions.
Compound- for example M105 This type of product should only be used once or twice for the life paint.
