holograms all over a 2007 Honda Laguna Blue Pearl S2000
flb18r
Holograms all over a 2007 Honda Laguna Blue Pearl S2000
Hello everyone, as some of you know Im new to detailing and new to rotary buffer (makita). I did my 1st two details begining of this week. one was a 08 vw passat sliver, which came out goood. but my friend's S2000 came out with halograms everywhere. The car has moderate imperfections. meaning wash*clay*swirl removal* polish* glaze* wax* QD*
here what went wrong* detail started at 4pm-9pm. we was in a hurry, so I learn my lesson: either do it right or no do it.
  1. foam wash, two bucket hand wash, top to button, flood rinse car, QD it down and dry top to button, blow dry.
  2. clay with lube
  3. QD it down and dry
  4. Makita buffer * at 1500 rpm* White LC 8.5 foam pad* Meg 205 * consider me moving buffer too quickly.
  5. Makita buffer * at 1200 rpm* Black LC 8.5 foam pad* Four Star Machine Glaze & Polish *
  6. when back and fix some halogram, successfully on hood with step 5 by moving slowly.
  7. QD it down and Wax with Meg M16.
so now I have a PC with edge double side foam pads kit, I like to use the PC and fix it. question is HOW? I have Meg 83 105 205, and whole line of four star product in 16oz
or
with the rotary again.
:buffing::buffing::buffing::buffing::buffing:
As you said in #4, you probably did not cover all the defect by moving the buffer too quickly. Don't be afraid to move slowly... that is what practice panels are for so you know how slow you know to go without heating up the panel too hot or burning it. Going fast is not going to correct anything... not sure if you have practiced on old panels yet but it will indeed help you out...
I did practiced on panels before this, we are planing to correct the holograms at 12/28 with the PC. my plan is use the PC with the Edge double side 6in White pad at speed 4 or 5 with Four Star Machine Glaze & Polish.
flb, you can do as stated above or just use your pc with 205 to finish down with no holos. BTW do 18X18 areas at a time.
I would use M205 with the finishing pad/PC instead of Four Star. Speed 5-6 with moderate/light pressure and you should be golden. Luckily the paint on these cars is very soft, so it should not be hard to correct.
I agree. If after this step you are not removing the holo's then keep using M205, but switch to a polishing pad.
It's really hard to finish out 100% swirl-free with just a rotary buffer especially if you inspect for swirls after the last rotary buffers step.
Some people just wax afterwards and don't see them and think they're creating swirl free finishes.
Do like the others posted and switch over to the PC and re-polish each square inch on the 5.0 to 6.0 speed setting with one of the swirl mark removers you have.
Do a TEST SPOT first and make sure your pad and product combo is truly removing the swirls before going over the entire car.
Removing swirls means removing paint and how much paint you have to remove with the PC depends upon how deep the swirls are that you put into the paint. The more coarse or aggressive your compound abrasives, the more tatty or worn you buffing pad is and the harder you press, these are all factors that can make deeper swirls.
So test first and once you dial in a successful recipe then go over the entire car.
After you do you test spot, wipe the spot down with some Isopropyl Alcohol or some Mineral Spirits or wash with a detergent was and make sure the paint still looks swirl free after stripping it.
Don't worry if stripping it makes it look less glossy as that's normal, you can easily restore the gloss, what's important is to make shure you're removing all the swirls.
And for all the lurkers reading this wondering about swirls and rotary buffers and dual action polishers... read through these two recent threads...
What am I doing wrong - Holograms after using the rotary buffer
and
4 part process still has swirls?
Notice how in both threads, the person started out with a rotary buffer and ended up with swirls. Then they switched to a dual action polisher, (the changed the action of the tool they were using), and then the were successful at creating a swirl free finish.
Note the dialog all the way through each thread.
:buffing:
Thanks everyone, these two cars I detailed are both my friends. The passat owner inform me that there are white residue on rubber seals around the windows, I did use tape, but guess I didn't do a good job. I don't really know how to pick up a line of product, I spread it and mist the pad, therfore it can be messy.
I don't think I need to use compound, the s2000 is in moderate condition
This is a good next step at this point in the projects.
No matter which version of Porter Cable you have, you need to be on the 5.0 to 6.0 speed setting. In order to remove swirls, the pad must be rotating ageists the surface, not just vibrating.
Holograms, also called Buffer Trails or Rotary Buffer Swirls are a type of below surface defect. Everything you need to know about removing below surface defects is explained in detail in the below thread.
Tips and Techniques for using the PC 7424XP Dual Action Polisher to remove Below Surface Defects
Also notice how in some of the pictures you'll see there are black lines drawn on the back of the backing plates used on the Porter Cable Dual Action Polisher, this is to make it easy to see if the pad is in fact rotating or just vibrating.
Use a permanent marker to place a line on the back of your backing plates to make sure your pads are in fact rotating while removing swirls and not just vibrating.
The Four Star Machine Glaze & Polish is stated as being able to remove compounding haze, fine sanding marks and light scratches with a cutting pad so test with the polishing pad to a small section first and make sure you're getting GREAT results using a polishing pad.
After I compound a car, even with all the edges taped off, I still wash all the dust and residue off afterwards...and I usually take some Menzerna Top Inspection and spray EVERY little crevice/crack/emblem/you name it and wipe inside that area with a microfiber. This always ensures that you'll have no residue left in the cracks.
heres the s2000, the rear quarter panels shows the holograms, he says its hard to capture.
before I was in AG, I throught the hardtop paint job was very good. after all the knowledge I gain here ( thanks to you all), the paint job is crap, sand marks are still there, lots of overspray, mis match colors, on and on. dents.
before I was in AG, I thought the hardtop paint job was very good. after all the knowledge I gain here ( thanks to you all), the paint job is crap, sand marks are still there, lots of overspray, mis match colors, on and on. dents.
Is there any update to this thread?
Have you removed the swirls successfully?
No sorry, I havent got a chance to do it, its been very cold here in NJ. I stack up a whole shelf of products cause of AG having it's sales. I can't wait to use it, I have a 05 Mazda Miata ( purple ) 10 Vw GTI ( gray ) some DD Toyotas, and maybe more will sign up.
im trying to inform my co-workers in the dealerships that the Detailer does a crappy job, still they don't believe I can do better. I guess I gotta prove them wrong. but Im not gonna do it for $60 like the detailer is charging them lol, Im not trying to take business away from my dealership, just informing my CO-Workers, not customers. so sad to see a $50,000 + car deliver with swirls, can't do anything about it.
Thanks for the follow-up...
I noticed this was a Sticky in the Circular Polishers forum group but when I read through it there was on conclusion so I thought I would revive the thread.
:dblthumb2:
