oneheadlite
- Aug 20, 2015
- 1,791
- 94
Hey Gang
Looking for input from folks on if anyone has experience with more industrial options for home carpet cleaning.
We pretty much annually have a company come out and do all the carpets in the house, and it's hard not to look at that bill and start wondering how much you could do it for yourself. I've got a little spot bot for light duty use, and a full size bissell or hoover thing that's your normal home grade carpet shampoo'r. While it worked fine when new, it never blew me away, plus now that it's got some (mostly idle) years on it it leaks from the fresh water/soap mixing valve o-ring.
Poking around a little it, I found the Bissell Big Green Machine (86T3) and it's "commercial" counterpart the BG10. Sounds like they're largely the same machine with slight variations of plastics used and power cord. I could pick either of these up for less than a full house carpet cleaning.
Anyone have any experience with either of these machines? One thing I like about them is the availability of repair parts if needed. Plus the option to use a hose so it could be used for more thorough automotive use as well.
I'm open to advice if there are other options that really stand out to look at.
