FUNX650
- Dec 1, 2010
- 21,057
- 2
Then, by knowing these factors, and:When the manufacturer says 180 MPH, I'm not sure where they are measuring that. If you are using the same orifice as the manufacturer, then yes. If you are using a bigger orifice, then velocity decreases, if using a smaller orifice, then velocity increases.
Pumps generate potential energy (head) and flow rate in the fluid. You'd want to know the CFM of the unit, (knowing the head would help, but unlikely to find that info) and details about the piping configuration and the orifice (outlet nozzle), from that, you could roughly determine velocity.
By use of the applicable Bernoulli's principle/equations...
the desired (combined) velocity rate would be derived
