ndsports
- Jan 23, 2015
- 14
I wanted to share a homemade undercarriage wash device that is good to use for the Garden Hose washer. I do not use a pressure washer. For people with pressure washers you can buy a special undercarriage washer attachment.
For your typical garden hose user this works pretty good and the pressure is good too.
We built this device a little longer the guy who makes the "Underwasher" so we don't have to bend as much when using it. Also you can hold it upright rinse the top of the truck.
One: 10 foot 1/2" PVC.
Two: 45 Degree 1/2" elbows
One: 1/2" PVC Pipe Cap
Pvc: Glue or Glue & Primer
one: 3/4in x 1/2in Swivel Hose adapter: Ace hardware part #48479
Ace Quick Connector Hose Coupling Set.
This took only 15 minutes or so to build. We had the hardware store cut the 10 foot pvc in half. We decided when we got home, the wand part that shoots the spray, we only wanted roughly 2 1/2 feet of it so we used pvc cutters to cut the piece. We used the spare piece later to act as a handle.
We drilled holes roughly every 4 inches or so and added a few angled holes to get different directions of spray.
we glued the two elbow pieces, the end cap, and the swivel hose adapter. We then took the quick hose connector and screwed it in. We can pop the garden hose on and off as needed and quickly and also control the pressure.
You could cut the 5 foot piece down a foot or so, but we wanted to make it longer to reduce bending.
Quick YouTube video: http://youtu.be/qoYKUqY9rv8
