Honda Civic - Orange Peel Removal & opticoat-ed
zckid
Hello friends
A very good Thursday from Mauritius
This detailing job took over 5 days, from decontamination to coating, loads of defects removal and paint leveling.
Upon arrival:
Wash:
2BM method using mf wash mitt
Local car shampoo and APC mix
To the wheels
Washed already:
close-up of contaminants
Decontamination with Sonax full effect + Clay
in- process
Ready to be coated and protected
To the paintwork
Clay
Assessing the work to be done
Not easy to be noticed. On this color, it’s as if the defects have got “shyness DNA”
From previous respray job, rubber trims damaged! I was very sad for the friend who brought his Honda to me. Little or nothing I could do for that.
NEW paint defect (at least for a newbie like me, doing detailing as a passion)
More familiar
light scratches and RIDS, full of swirls but the metallic flakes just make it difficult to be captured.
The headlights
wait, not yet over
the lower sections
subsurface defect
Look
close-up
same on both sides of the rear bumper
Paint correction:
The paint has sanding marks and scratches beaneath the clear-coat. I had to proceed with extreme caution and to add, Hondas are the champion of soft paints.
Tools: Makita rotary, Flex 3401
Polishes: Menz FG 400, 203S, PO85rd
Pads: Carpro denim pads, LC white, LC HT Crimson, LC white
Glass: DP Glass restorer with glass polishing pads, Opti-sealed
Wipe down : IPA mix
Coating: Opticoat with supplied applicator, wiped with suede mf towels (better than normal mf towel IMO)
Trims & tyres: CG new look trim
After correction
a spot or 2 remain, would have needed more clear coat removal
The roof
close-up
More swirls appearing due to a flatter surface, holograms are there too from the compounding step
My friends
Beading during the polishing stage
Checking and checking
TA DA
Attending to the details
Focussed
menz 203s
rare incidence: Shot by Mrs
extreme close-up
Amazing work and very detailed write-up with excellent photography work capturing the before and after results.
thanks a lot Mike. You have been an inspiration to me since I got interested in detailing :iagree: Others are included too
Cheers all the way from our small island to u, and the whole AGO team and forumers :dblthumb2::dblthumb2::dblthumb2:
Had to move, so here is the rest of the post
The hood
The task at hand
Many scratches found after compounding, when the blurriness is gone
Inch-by-inch inspection
More inspection
The Sun test
The swipe test
Finishing beads
Feeling blessed
The boot lid
Peek-a-boo wih the sun
Perfection wanted :buffing:
Couldn’t get the sun from the camera, but no swirls left
The doors and vertical panels
To recap
Orange peel and textured paint removed
Almost done
Hello!
I’ve still got an agricultural garage/workshop Im the MAN
A few reflection shots
[B]Some Finishing beads[/B]
Coating the mirror
Some opti-beads shots
The Finishing pics
Thanks for reading. Your comments and thoughts are most welcome.
Cheers
Zaid
Great work
Great Write up
Thank you very much
What was your experience with the CarPro Denim pads for OP removal
Any details would be great.
-Speed
-Pressure
-Rotary or PC
-3" and 5"
-FG400
-# Passes
Awesome work, do you use any special marker, or just a plane old sharpie?
Thanks a lot bro
it's the simple whiteboard markers that I use. (the non permanent ones).
It goes away when you buff or wipe with a mf towel
Great work
Great Write up
Thank you very much
-Speed
-Pressure
-Rotary or PC
-3" and 5"
-FG400
-# Passes
Thanks for your kind reply Allen. :dblthumb2:
The denim / velvet pads are made especially for the rotary, not DA.
there's a learning curve with the denim/velvet pads. get yourself a scrap hood or panel and try 1st, until you become used to it.
But it does remove orange peel with the right compound.
but remember denim pads are not forgiving (esp, on edges and curves on the panels, where paint forms sort of a valley at the edge) as far as possible keep your pad flat. Once you do a panel wait until it's cool to rework it. you have to be twice cautious. :dblthumb2:
else you can achieve high correction with it (you can tackle scratches, orange peel or pits and pores etc...) and finish in 1 or 2 more steps
:buffing:
With FG400 and the denim pads, I spread the polish on the panels first rather than on the pad itself (my preference) as I'd do with all the normal buffing.n I work it for one pass at appr. 900-1000 rpm, then increase to appr. 1300 to 1500 with medium but steady pressure, moving my arms slowly to get the best of the cutting action.
I'm not a pro yet, just the enthusiast learning from online forums and videos. I learned one thing from the rotary. "adjust your arm movement to go with the flow of the rotary".
1. You'll get tired less
2. most importantly, you'll avoid damaging the paint with the denim pads, i mean the edge of the pads, a wrong movement (tilted, at an angle, or near the edge) at speed 3 on the makita = high possiblity of flake off.
For the number of passes, it will depend from panel to panel and the extent of texture on the paint. 4 -6 passes in general will do.
You can finish with Menzerna 203s on a polishing pad with a DA since the surface will be flatter after using the denim pads. Or you can have 2 more steps if you wish.
If yours is factory paint, u can use the velvet pads. but do practice on a unused panel and finish in more step. the velvet pads are equal to 3000 grit while denims = 2000 grit
there's a post by Todd Helme on autopia forums on this subject. please have a look at it. it's very detailed
thanks and do bring us the :buffing: pics
