plastic panels are a pain in the rump to remove scratches from and getting a near flawless finish, best bet would be using some 800grit wet sandpaper to level off scratches, go to 1000 grit to remove 800grit sanding scratches,then go to 1500, then 2000,then finish with 3000 grit. you may not need to use the 800 depending on how deep they are. remember also, with plastic its alot softer then paint so something like m205 might remove the 3000 grit sanding scratches from the plastic then go to some plastiX and see how it looks. plastic really is a pain because of how soft it is, just using some compound alone most likely wont remove the scratches if a finger nail catches, if no finger nail catches might get away without sanding. just try some test spots and find out what works, even the best of the best detailers need to do test spots and find out what works on the fly as paint systems vary so much, can have factory paint on all but one panel then that one panel uses a different paint system, im sure you get my point. just test some product/methods and report back!and post pictures so we can help you better!
(i do not detail motorcycles but ive done some plastic polishing/plastic work so thats why i replied. my motto is if i cant drive it, i dont detail it.) yes i know that limits me but i dont do motorcycles, im the type i get on one and knowing my luck ill fall right over LOL...i cant even ride a 49cc scooter without dumping it!
