Honda Ridgeline (07) Truck
carguy
Here is a truck I did a couple weeks ago. Honda Ridgeline (07) 4 wheel drive.
Process: Interior Wipe interior down with The works apc cut 1:8
Widows with Perfect Glass/carpets vac/ matts extracted with Brissle Green machine/with heater/ spray matts with zep citius degreaser.
Process: Exterior: PW/with electric washer rims,wheels,wells used citius degreaser.
PW engine with citius deg.
PW exterior with foam attachment and Nxt soap.
Dried with guzzler.
Dressed exterior with black again trim cream.
Da used with xmt 2 with white polish pad on # 5
Wipe exterior with 50/50 alcohol.
NXT Paste wax applied with foam pad let sit for 20 minutes
Meguires high endurance gel on wheels.
AA foam on wheel wells.
total time 5hours 40mins.
comments welcomed.
Very nice detail. Thanks for taking the time to write this review. You have some good reflections going there.
Thanks for the comment. Takes a while to get the right shots, will try the products on the ground with the cement wet to see how that differs in appearance.:righton:
Looking good...Can you make the pics bigger? I think they downsized a little to much....
