I am going to order a carpet extractor this week the Mytee HP60 Spyder Heated.
Any thoughts or opinions on this would be a great help.
Thanks In Advance
Dean
Word to the wise, only put water in your extractor. Let the chemicals dwell on the carpets, scrub with a brush and extract with water only. Cleaner carpets and no residue left behind. The mytees are a very good machine so I hear. I have an Aztec Hot Rod and it is very good as well. Not as big, but because I do mostly mobile it works great.
You can ask around, the shampoo that you squirt out isn't going to do much for the brief few seconds it is on the carpet. It is the fact that you let the chemicals dwell and then hit them with the hot water that will get them clean. I believe and many others do as well, that spraying carpet shampoo does nothing more than limit the life of your machine.I guess I do not understand why they sell extractor shampoos...my extractor instruction clearly state to use in the solution tank..and give mix ratios for conditions...
Al
