flamesagent
- Aug 3, 2017
- 7
Question: I have a cold water pressure washer. The water flow is: Water Tank->Water Pump->Pressure Washer. Between the Water Pump and the Pressure Washer (Subaru 3100psi) I am thinking I can install some form of hot water heater in order to deliver hot/warm water to the pressure washer for output. Trouble is, I am not sure if this can be done and, if it can be done effectively, what type of outdoor water heater could I use (money is a factor). The application is for commercial mobile detailing... not for home use.
Any guidance you could give would be greatly appreciated. Thank you.
